Meg The Mini 998
16 replies to this topic
#1 corrado vr6
corrado vr6
  • 678 posts
Posted 03 December 2011 - 12:36 PM
Well The story goes this minis not mine but my brothers and his fiance, but im going to be doing a full rebuild on the mini called "Meg" and then a full respray in.... well the colour hasnt been chosen yet! First things first is to obviously repair all the rust! so here it goes and let me know any of your thoughts and ill be making sure this is kept updated as i let my last rebuild thread slip
All stripped subframes and Engine all removed
Wing removed shame as there was no rust on the wing but plenty of rust and old patches behind!
in the mean tine i have been also working on the engine, have sent the head off to be converted to run on unleaded fuel with new valve seats, when i got it back i have painted and will be doing the same with the block and gearbox later
other wing removed to start work on the flitch repair i have welded in the repair on the n/s but havent got a pic of that yet
Flitch repair started on the o/s
#2 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 03 December 2011 - 12:56 PM
looooookin gooood :proud:
#3 corrado vr6
corrado vr6
  • 678 posts
Posted 28 December 2011 - 08:40 PM
Bit of an update
patch made to cover the air intake still not sure if im going to open this back up yet or leave closed to stop future tin worm
Parts ready to get shot blasted and powdercoated
inside of the door to be shot blasted
Subframes back from powdercoat
Door opening braced and passenger door step removed
#4 corrado vr6
corrado vr6
  • 678 posts
Posted 28 December 2011 - 08:48 PM
Door step tacked in
With one end completley welded and tidied up i will spot weld the step to the inner sill after i have replaced the inner sill and front footwell then i will replace the outer sill
#5 corrado vr6
corrado vr6
  • 678 posts
Posted 28 December 2011 - 09:00 PM
Then i started on the drivers door by replacing the bottom
made a patch for the top of the door frame
and made another patch for the lower curve lip of the door
and spot welded and seam welded the patch in
unfortunatley the passenger door is a bit past it so im on the look out for a cheap passenger door at the mo
Thanks for looking
#6 grahama
grahama
  • 2,442 posts
Posted 28 December 2011 - 10:08 PM
Hi,
some very nice work going on there. Keep it up.
Graham
#7 Tupers
Tupers
  • 4,156 posts
Posted 29 December 2011 - 02:42 AM
Some nice welding work you've got going on there, I like the silver frames.
#8 corrado vr6
corrado vr6
  • 678 posts
Posted 15 February 2012 - 10:16 PM
Well some more progress
On its side with the oversill removed
bit of rust
all cut out
Inner sill or (floor really) replaced, arch repaired, closing plate and heel board replaced, had to put subfrmae back on to make sure it all lined up before welding
new door step and outer sills all spot welded together so much neater than before!
rear arch end cut out and boot floor corner ready for repair panels
view of messy workshop through mini boot floor
#9 mk1leg
mk1leg
  • 9,343 posts
Posted 15 February 2012 - 10:22 PM
Nice work going on there keep pics coming................ :proud:
#10 corrado vr6
corrado vr6
  • 678 posts
Posted 02 June 2012 - 10:26 AM
Thanks for all the comments
unfortunatley my iphone crashed and had to be rebooted which meant i lost alot of pics of the build upto this point which is a shame :(
but hey ho heres where im at
off cuts and bits removed, its scary theres actually more if you include the door skins and wings
#11 corrado vr6
corrado vr6
  • 678 posts
Posted 02 June 2012 - 10:28 AM
underside all etch primed, primed again, seam sealed and stonechip
#12 corrado vr6
corrado vr6
  • 678 posts
Posted 02 June 2012 - 10:32 AM
Posted ImagePosted ImagePosted Image
#13 corrado vr6
corrado vr6
  • 678 posts
Posted 16 June 2012 - 07:58 PM
going back in time slightly but have found some of the old pics i thought i had lost
#14 corrado vr6
corrado vr6
  • 678 posts
Posted 16 June 2012 - 09:02 PM
and some photos taken today finally sprayed
i put the windscreen back in quickly to make sure it still fitted after fitting a new scuttle
in primer
seam sealed which i then primed over again Posted Image
fitted the gutter trim to colour code it
stainless steel seam strips fitted and sealed in along the edges
sealed in the joins
IN COLOUR!!!
Just got to put it all back together now then :)
#15 corrado vr6
corrado vr6
  • 678 posts
Posted 24 August 2013 - 08:38 AM
Bit of an update, just realised I never finished this topic, however I finished the mini in time for the wedding ;)
Headlining in
BCDC3D93-612E-44B8-BF35-8B75532B3AAB-563
4C602412-CF7A-46BD-92AA-1F8E41401684-563
Getting her face back
317B0679-CD94-402C-9897-11BD86A8E1FB-563
Ready for an engine
FAB1109C-0AC7-40C9-A40D-601CC2EAFB89-563
Very happy with the door shut lines
F17BD748-E857-46FF-AF11-2579B12D3806-563
New brakes
04C0AF76-B7E2-4B0E-87F7-E34D8AC34B77-563
Engine having a full rebuild
06E39B2D-1647-407D-B07A-AFEC88D01365-563
B5DABBA6-6215-46C6-8EAA-1E1AEB25947A-563
C7DEFE7D-35B2-4EBE-B93F-5D5F03A909A3-563
4209E762-2BB0-4066-9699-49BE428AB8EE-563
76A6A08D-7FA7-4466-8C47-8A10DACFBE40-563
A78A63DC-B932-48F9-99CE-D356AFC423B9-563
804B8C9E-C5CA-4000-877A-00E98AA2D416-563
Parked next to mine
E0D1B4B0-7093-49EA-B310-0B04EBC80334-563
BCAB80DF-1240-4203-A680-6F12C5FB9C2E-563
1B5891B1-AC48-42B3-A2BD-ACC0E9C6472C-563
8423AC98-B509-44E9-8B7E-10C5DFEBC9DA-563
76299668-3D0B-4EDB-9F5A-E126D7E7202A-563
2B056BAE-D619-47C9-B34A-1EF369DBFADD-563
<a href="http://s177.photobuc...E09746AA5E.mp4" target="_blank"><img src="http://i177.photobuc...E09746AA5E.mp4" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
Passed mot first time :D
221AA693-FAAC-4BCD-8DF3-23BB63BCDF3E-563
E54E33FD-0573-4833-BEB1-B250A68C0F87-563
238E1FDA-93BE-4ECA-831B-0308AEBFD39B-563
FC4EF776-2438-4426-B6C9-B6AAFDD8BEE8-563
So there we have it all finished!
