Clutch Removal Tool
7 replies to this topic
#1 Daveuk
Daveuk
  • 429 posts
  • Local Club: friendly with any mini people
Posted 04 December 2011 - 08:01 PM
Hi everybody done the research to removing the clutch (also got the mini build dvd which helps loads) however i'm just wondering if this is over kill to get the damn clutch off as i've seen a few people snapping their tools alot!
http://www.minisport...o_TOL07001.html
or shall i just got for the usual sort?
http://www.ebay.co.u...1-/170369583300
http://www.minispare...ty=pb&pid=36627
http://www.minisport...OL660300SP.html
Any info is greatly appreciated
cheers
Dave
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 04 December 2011 - 08:04 PM
done 3 clutches with ours and its just one we got from Halfords LASER is the brand
#3 Cooperman
  • 23,293 posts
I've got one of the heavy duty type, but the centre bolt snapped a while back so I've bored out the centre and re-tapped it even bigger with a top quality high-tensile bolt.
#4 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 04 December 2011 - 08:11 PM
all about the heavy duty KAD flywheel puller, stands up to 15 mins of use of an impact gun!
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 04 December 2011 - 08:16 PM
I must have 3 or 4 flywheel pullers of different makes & types, and the one which is most used is a Sykes & Pickavent... mainly because the thread on the main bolt is a lot finer, therefore allows you to put a lot more pressure on the flywheel without resorting to long poles or impact guns.
#6 Daveuk
Daveuk
  • 429 posts
Posted 04 December 2011 - 08:31 PM
wow cheers for the quick replies guys
Dave
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 04 December 2011 - 08:32 PM
Just checked all those links, and those SP ones are not the same as the one I use.. so checked S&P catalog
Mine is the 'Universal Flywheel Puller' part number 08510100
Fits both manual flywheels and also torque converters, and the 'force bolt' is MUCH bigger...
http://www.sykes-pic...ssion Tools.pdf
Edited by Guess-Works.com, 04 December 2011 - 08:32 PM.
#8 bmcecosse
bmcecosse
  • 9,699 posts
Posted 04 December 2011 - 08:33 PM
Mine is a 12" square X 3/4" thick steel - holes drilled for the 3 fixing bolts, and a large nut welded over a clearance hole drilled in the centre - with a 1" diameter bolt fitted. It has never failed me yet........
