Cutting And Drilling Carbon Curley Dashboard... 52Mm Holes Etc?..
7 replies to this topic
#1 loobylooby
loobylooby
  • 76 posts
Posted 04 December 2011 - 09:58 PM
advice would be helpful people:) beffore i mess things up...
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 04 December 2011 - 10:02 PM
i would use a hole saw
battery drill with clutch on slow speed
#3 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 04 December 2011 - 10:20 PM
what bungle says, i did it on a GRP dash and it turned up nice!
#4 Tupers
Tupers
  • 4,159 posts
Posted 04 December 2011 - 10:21 PM
As Bungle said a hole saw is the tool for the job. I'd also add that it's a good idea to use a small amount of super glue to seal any edges you cut and save them from fraying.
#5 glyn
glyn
  • 637 posts
  • Local Club: leyland mini club
Posted 04 December 2011 - 10:46 PM
measure twice cut once! or 3 times in my case >_< :bah:
#6 MJWarren
MJWarren
  • 705 posts
  • Local Club: DCMOC
Posted 04 December 2011 - 11:23 PM
Id use a dremmel and have done before, a hole saw will cause the carbon to fray and it goes sort of a whitey colour where its broken on the edge. Each to there own.
#7 Stocky_s
Stocky_s
  • 54 posts
  • Local Club: BMC
Posted 05 December 2011 - 12:38 AM
i'd use a combination of both of the suggestions - hole saw 1 size smaller than you need then use a dremel to enlarge the hole :)
either way good luck :)
#8 loobylooby
loobylooby
  • 76 posts
Posted 05 December 2011 - 12:15 PM
thanks people :) might get some carbon and have a play first...
