5X10 Or 6X10?
Posted 05 December 2011 - 09:37 AM
What wheel is better? 5x10 or 6x10? are the tyres more expensive on one of them and which handles best?
Josh
Posted 05 December 2011 - 09:42 AM
Hi,
Josh
Tyres, assuming you're going for 165s, are the same.
And 5x10 will handle better due to less weight.
Posted 05 December 2011 - 09:57 AM
Posted 05 December 2011 - 10:09 AM
Posted 05 December 2011 - 10:43 AM
I would have said 6inch would handle better. More surface area = more grip. I may be wrong though. Wont be the first time.
You get no more surface area as the tyre width is still 165 mm. The only mechanical difference is that the mean centre line of the wheel will move out 1/2", assuming the same offset between mounting face and inner rim position. This slightly alters the steering geometry which is better with the 5" wheel and is why the 4.5" wheel was always so popular.
Also, more surface area does definately not mean more grip. A specific type/pattern of tyre will have an optimum down pressure onto the road. This is expecially important in the wet where a wide tyre can simply not have enough down-force to clear the water - hence 'aqua-planing' and sliding. If you look at tyres fot ice and snow they are narrow.
And remember, the wider the tyre the more aerodynamic drag so the less top speed. For best top speed in a straight line you need narrow tyres and no wheel arch extensions.
Posted 05 December 2011 - 11:02 AM
From what i have read so far the 5x10's seem to be the better choice.
Posted 05 December 2011 - 11:04 AM
Posted 05 December 2011 - 11:24 AM
Posted 05 December 2011 - 11:27 AM
Posted 05 December 2011 - 03:48 PM
Posted 05 December 2011 - 04:40 PM
Cheers james
Posted 05 December 2011 - 04:46 PM
Hi, im running 6x10 mamba wheels and i need the group 2 wide arches as the wheels stick out to far with the normal grp 2 arches and thats not using spacers
Cheers james
Even the original 5x10 mambas that i had protruded past standard group 2 arches. So as jaydee said check with the supplier as to the offset of the wheels.
Posted 05 December 2011 - 05:03 PM
as in 1" extra. my split rims were 3 piece and all the 1" was not on the outside this was on race car
I realy do not think a 6" rim with the extra 1" on the OUTSIDE will be as good as a 5" rim
with the same tyre for all the reasons cooperman says
however the do look nicer
I have 5" on mine but would like to TRY some 6" see what happens as as far as i can see all the wheels seem to
have that extra 1" on the OUTSIDE
5.5 would be nice
Posted 05 December 2011 - 05:06 PM
should say NOT ALL 1" on OUTSIDE
cant edit it
