Donald - 93 Cooper,fast Road,full Resto
#16
Posted 19 January 2016 - 08:38 PM
#17
Posted 19 January 2016 - 10:19 PM
I've wrapped up the orginal interior and any spi specific parts put them in the loft!
This is my new plan:
Full nut and bolt rebuild,
new engine rebuild torque/fast road spec + gearbox rebuild
Still going for 10's
On 7.5 cooper s brake's
MPI engine on specialist components 5 port kit in possibly in preparation for supercharger
Mk1 flipfront
Riley elf dash
Brown interior
Rollcage
Copper color details
Respray in either a dark shade of Brooklands green or Connaught green
#20
Posted 23 January 2016 - 04:38 PM
This should be the final time I have to lug the shell around due to moving, so happy I finally have a place to work on it!
Also collected hobbyweld bottle + adaptor,
Next up is making a welding trolley and getting shell on spit.
#21
Posted 04 February 2016 - 07:25 PM
Started by clearing out the shell, cleaned and boxed parts and stored away,
Before:
Hooked up extra lamps on clamps so I can actually see what I'm doing for prep,
Then removed the pedal box as it was bugging me
Then I decided to start on removing the scuttle panel,
Also cut out the chassis stamped part of the scuttle in preparation to fit to new scuttle,
First time using a proper spot weld cobalt drill bit as recommended, drilled slowly to try and not go to deep into the next panel, happy with the results
Edited by cityspeed, 14 February 2016 - 08:16 PM.
#22
Posted 10 February 2016 - 04:06 PM
Ran out of gas on my last little bottle, so the rest of the day was spent sourcing a regulator for my hobbyweld bottle,
My plan for a welding trolley, I'm going to take the lid of my roller toolbox, mount welder in top, then build a bracket on side to mount the bottle,and its red so will match the welder! ;)
#23
Posted 11 March 2016 - 05:20 PM
Had a few issues getting it level, also my locking bolts grip the pole but are not man enough to lock it at 90° , going to drill through it and stick a bar through to act as lock
The underside is a little better than I expected:
1 oversill P/S, a plated oversill D/S which is only half the length appears to have been dressed but poorly treated
Heel board is bad.... Think in going to do front floor pans to make this easier
Boot needs rear repair, and repairs around subframe mounts,
Rear arches are good
Oh and it's had a genuine rover side panel fitted on P/S so hopefully those areas will be in better condition than D/S
Edited by cityspeed, 09 January 2017 - 11:14 PM.
#24
Posted 11 March 2016 - 06:47 PM
nice project
#25
Posted 11 March 2016 - 07:21 PM
I love the colour of those doors! :)
looking good
#26
Posted 11 March 2016 - 07:46 PM
They really should save me alot of time, boot lid is great aswell, I was inspired by your build by the way, its given me a kick up the backside.
#27
Posted 11 March 2016 - 08:11 PM
Well they disappeared in the night whilst moving house, I suspect it was the do as you likey's
Left them in a unlocked shed, chances are they eyed up the car but fortunately I moved it shortly afterwards, due to the stress of the move I didn't realise we they were gone until I went looking for them.
Brought a replacement set in a joblot (the dark blue ones) in earlier photos but have decided to stick them on eBay, as they both needed re-skining and frame repairs.
Got a great set off "sawyer" on here, only need a small amount of work result!
#28
Posted 11 March 2016 - 10:45 PM
Cheers dude!
That's great, look forward to seeing it when it's done.
#29
Posted 16 March 2016 - 12:50 AM
