First patch of the day,
Started clamping up, first time using the skin pins
Closing panel and heelboard repair trial 1
Subframe test fit
I welded these bits of box on beforehand so I have reference points
Need to trim my repair down, but looks like it will work so started dismantling it all so I can adjust a few pieces
Cleaned off the e coat from the closing panel, coated it in weld through primer so should save me some time tomorrow, started on heelboard prep but called it a day when I PUNCHED MYSELF IN THE FACE ! , with the skin pin pliers..... Was inside shell with no space must have been tired as I didn't react when I removed a stubborn pin. Starting early tomorrow morning not going to let the mini beat me up!
Edited by cityspeed, 07 February 2017 - 04:07 PM.
