i have a 1966 mini i am restoring from the ground up i have pumped the hydrolastic up but there appears to be tiny weaping pin holes in the main steel lines, how do i replace or fix this without pulling the whole car to bits again?, can i replace these with hoses instead of pipes?
Leaking Hydrolastic Pipes
hunter
, Dec 06 2011 09:31 AM
4 replies to this topic
Posted 06 December 2011 - 09:31 AM
Posted 06 December 2011 - 07:30 PM
I used to have a '66 Mini with hydrolastic. The steel front to rear hydro pipes can be replaced with plastic ones.
Mini Spares sell them.
http://www.minispare...id=33478&title=
Posted 06 December 2011 - 08:52 PM
as above, but if you drain the fluid out you could braze the pin holes up.
Posted 06 December 2011 - 11:49 PM
I've got hydro and this is something that will probably happen to me. Just for reference, my understanding is that different equipment is required to drain a system than to just do a pump up.
http://www.liquid-le...om/hydravac.htm
v
http://www.liquid-levers.com/psp.htm
Charlie
Posted 07 December 2011 - 09:01 AM
thanks for that i was looking in to maybe using hydraulic line so i could just cut steel lines out and replace with flexable line so i didnt have to take the subframes out?, i have the pump at home to remove fluid and pump the system up again, same piece of gear for both it just has different functions
