I have a 1993 Italian Job, and my RR drum brake has an issue with binding every 3/4 of a turn. I have so far replaced;
- Drums
- Shoes
- Springs
Posted 07 December 2011 - 08:04 PM
Posted 07 December 2011 - 09:01 PM
Posted 07 December 2011 - 09:13 PM
Posted 07 December 2011 - 09:24 PM
Posted 07 December 2011 - 10:35 PM
Posted 07 December 2011 - 10:37 PM
Posted 07 December 2011 - 10:46 PM
slave cylinder ? although would expect that to bind all the time really....
Posted 08 December 2011 - 07:06 PM
Tighten the brake adjuster until it just won't tiighten any more, then back it off until the drum rotates with just a slight resistance. If it does not then turn evenly, albeit with some resistance, the drum is possibly ovalised slightly.
Posted 08 December 2011 - 07:19 PM
Edited by ministar, 08 December 2011 - 07:22 PM.
Posted 08 December 2011 - 07:27 PM
Have a look at the right angled pivot joint, which is to do with the handbrake! The pivot gets mucked up then rust fuses itself together. If it doesnt move, take it off and free if off till it moves freely.
Edit... Minispares product http://www.minispare...ty=pb&pid=33289
Posted 10 December 2011 - 09:02 AM
Posted 10 December 2011 - 09:47 AM
Posted 10 December 2011 - 09:56 AM
If it's a constant fault you could detach the handbrake linkage to eliminate it. Opening the bleed screw would do the same for an hydraulic fault. Are you sure the shoes are fitted the right way round?
Posted 10 December 2011 - 10:45 AM
Posted 10 December 2011 - 01:03 PM
