White Smoke Whan Cold
Posted 11 December 2011 - 02:01 PM
few things to mention, it does take about 2 goes to start her up and im topping up with oil frequently...temp gauge doesnt work but im sure its not overheating as the rad is always full, the thremostat has been swapped for a blanking sleeve ages ago too.
now if im correct in thinking its burning oil by the fact im having to keep topping it up shouldnt it be black smoke?
any info or suggestions what possible things this could be are all welcome!
cheers
Posted 11 December 2011 - 02:19 PM
is it white smoke that you are seeing or just condensation?
Posted 11 December 2011 - 03:01 PM
Any old car will have a lot of white smoke when starting. Mine does the same, its just because its very cold in the mornings, after about 5 mind of the choke it clears and its fine. Its perfectly normal.
Posted 11 December 2011 - 03:06 PM
So you could check for oily patches after the mini's been sitting for a while. Or if its a small leak then check for oil spatters under the mini around the bulkhead area and where the exhaust curves under the mini.
Or you could find its just where its cold as I said on my previous post.
Posted 11 December 2011 - 03:22 PM
ill have a look at the plugs and see, maybe good to replace them too while im there...i mean there are a few leaks regarding the oil but thats quite common i think... ive not measured how much is lost but after a few days , i could be putting around 1-2 litres of oil back in...so i think oil is deffinitely going somewhere but there have been no obvious large pools on the ground when parked up...
Posted 11 December 2011 - 03:31 PM
Posted 11 December 2011 - 03:32 PM
Posted 11 December 2011 - 03:33 PM
Posted 11 December 2011 - 03:35 PM
Posted 11 December 2011 - 03:38 PM
Posted 11 December 2011 - 03:40 PM
Posted 11 December 2011 - 03:46 PM
It's never the valve stem seals (unless they have not been fitted?) - straw clutched at by many......
EH???? .........Make up your mind man!!!
You seemed to think that my valve stem seals could be the cause when I had a similar problem!! ......
.............or were you just one of the many "clutching at straws" on that occasion??
My Mini seems to be puffing out a bit of blue smoke on start up, it then soon clears and doesn't seem to reappear again until the next time I start her up again. Someone I was chatting to reckons that this sounds like a symptom of worn valve stem seals, does this sound plausible or is it more likely to be caused by a different problem?
It could be - but just think of it as good cylinder lubrication at start-up.........
Edited by AVV IT, 11 December 2011 - 03:48 PM.
Posted 11 December 2011 - 03:55 PM
Posted 11 December 2011 - 04:02 PM
