Megajolt And Fuel Cut Off
Posted 11 December 2011 - 07:40 PM
have seen some info about fuel cut off on override - I think thats only poss with injection, carb's float chamber will be full anyway. Am i right in this thinking, or is there a way to mod carb so on override no fuel is wasted as in modern cars?
Posted 09 May 2012 - 06:02 PM
Wired in a relay so fuel pump is not active when car has no vacuum in manifold.
Still thinking of having a electromagnetic valve in the SU 4 carbs small pipe from float chamber to the jet. Megajolt could operate this say when the vacuum is on the override levels? Going downhill no fuel waste? Someone have seen something like this?
Posted 09 May 2012 - 07:23 PM
Posted 09 May 2012 - 07:30 PM
Posted 09 May 2012 - 09:05 PM
I belive if you have a search on the net you can find some infos about that, it has been done in some US spec cars..
Posted 09 May 2012 - 10:51 PM
the charcoal cannister is to trap the petrol fumes and feed them into the engine to burn off... an emissions thing...
I really cant see what benefit the OP is expecting by having the pump controlled by the megajolt...
Posted 10 May 2012 - 03:39 AM
Modern cars when braking, going downhill, etc, with engine revving waste no fuel for turning the engine, while carb still draws fuel from the float chamber. My thinking was with simple valve the flow to the jet would stop, and the flow would resume once the accelerator is depressed.
The fuel pump thing is another story. Its a safety feature, when no load in the type of manifold pressure = engine not turning, fuel pump is not needed.
Posted 10 May 2012 - 07:12 AM
Posted 10 May 2012 - 08:03 AM
Posted 10 May 2012 - 08:07 AM
like this!
any ideas, comments, criticism?
Posted 10 May 2012 - 11:35 AM
seems i need to explain this more. I mean two separate things.
So you would cut the fuel when the car is under deceleration, i.e. when the vacuum in the manifold is at its highest?
Posted 10 May 2012 - 12:15 PM
Posted 10 May 2012 - 12:30 PM
You're approaching a set of traffic lights a bit too quickly, so you slam your brakes and take your foot off the accelerator the fuel supply is cut, when you reach a stop I can see 1 of 2 things happening, either the engine will stall as it won't have the fuel to just idle and will cut off (there will be lag between fuel being supplied and the engine using it fire back up).
OR
if you have in gear still you suddenly get a jolt forward as the engine essentially restarts itself.
There's also the consideration that you will be running lean when decelerating.
If I'm honest I can't really see this being a practical or useful idea for a carburettor car...
Edited by liirge, 10 May 2012 - 12:30 PM.
Posted 10 May 2012 - 12:37 PM
Keep thinking about this every time I'm coming home, travelling down the one road that is about 3 miles of slight downhill following people doing 25-27mph (just low enough so I have to be in 3rd gear rather than 4th). I'm sure it's not massive amounts of fuel being wasted but every little helps.
I've got a HIF44 though, so can't even do what you were thinking.
One thought I had was a valve on the inlet manifold that would open allow more air to be sucked in resulting in leaner mixture (similar to cutting fuel). But, then it occurred that doing that would actually reduce the vacuum, and as youwould be triggering it by high vacuum (deceleration) it's not going to work....
Posted 10 May 2012 - 12:41 PM
Edited by liirge, 10 May 2012 - 12:41 PM.
