sorry to open another topic on coilovers, but i was wondering what lb and length springs other folks have used on their rear coilovers.
i have just removed my protecs to inspect them, and have found the springs are progressive 100/200lb ones and im looking to go softer.
so.... what do you lot use on yours?
What Lb Springs On Rear Coilovers, Lightweight Mini.
cradley-heathen
, Dec 13 2011 11:07 PM
3 replies to this topic
Posted 13 December 2011 - 11:07 PM
Posted 14 December 2011 - 01:43 AM
What angle are the shocks to the vertical?
Posted 14 December 2011 - 06:45 PM
You could start at around 65 lb/in and go to 175 lb/in at just before full travel. It is vital to have 'rising rate speings' unless it's only for racing.
Make sure you have suitable bump stops to prevent the springs from Coil-binding' as that is unsafe.
There is a company called 'Coil Springs Limited' in Sheffield who will make custom springs. I've used them and they are really good.
Posted 14 December 2011 - 09:00 PM
thanks guys,
