Spotlight Wiring Problems
12 replies to this topic
#1 Eddy029
Eddy029
  • 24 posts
Posted 15 December 2011 - 04:52 PM
Ok so I've got some Wipac spotlights on the front of my Mini now, was fairly straightforward using the Ring wiring kit from Halfords, anyway the only problem I had was the main beam supply, the blue/white wire behind the grill was dead, no power going down there at all. So I had to tap into the main clump of wires next to the yellow relays on the left hand side of the engine bay. I found 2 blue/white wires, so hooked one up and tried it, worked great. However when I have the headlights on and I want to switch to main beam, the spotlights come on but won't go off, almost as if the relay was sticking. They go out as soon as I switch from headlights to sidelights only, but when I go back to headlights and select main beam they become stuck on again. Anyone know where I've gone wrong? :mmkay:
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 15 December 2011 - 05:13 PM
yes, you tried to tackle a potentially dangerous aspect of your mini with no technical or practical experience
do you also make your own fuel pipes out of garden vegetables and reline your brakes using bread and butter ?
the wiring on your car is as dangerous as the fuel system and brakes do not just fiddle with it and have a go, get this wrong and your mini will be nothing more that a smouldering mess on the floor
now quickly disconnect your bodges so far and get someone that knows what they are doing to do the job or use this forum and read up on what you are meant to be doing and only start when you are 100% happy in your knowledge and skills
#3 lrostoke
lrostoke
  • 6,923 posts
Posted 15 December 2011 - 05:17 PM
Sounds like a relay problem, but odd it goes when you switch to sidelights.
Just to be sure though on the relay
Pin 30 comes from your battery 12v feed (solenoid good place to take this) I'm presuming with it being a kit it came with fuse etc
Pin 87 goes off to your spot lights
The pins can be reversed for the above as long as either of those 2 is used for power in and out and vice-versa
Pin 86 comes from the blue/white wire high beam circuit
Pin 85 goes to ground, either black wire in loom or fixed direct to shell of car.
again these can be reversed, its the energising side of the relay
Edited by lrostoke, 15 December 2011 - 05:18 PM.
#4 1984mini25
1984mini25
  • 8,784 posts
Posted 15 December 2011 - 06:15 PM
anyway the only problem I had was the main beam supply, the blue/white wire behind the grill was dead, no power going down there at all. So I had to tap into the main clump of wires next to the yellow relays on the left hand side of the engine bay. I found 2 blue/white wires, so hooked one up and tried it, worked great. However when I have the headlights on and I want to switch to main beam, the spotlights come on but won't go off...... Anyone know where I've gone wrong? :mmkay:
So, your standard full beams don't work? So instead you have dangerously bodged a supply from somewhere else.
#5 lrostoke
lrostoke
  • 6,923 posts
Posted 15 December 2011 - 06:19 PM
He doesn't say his full beams don't work ??
And the blue/white will still be high beam circuit so how is it a bodge, my understanding is he's cut into the main loom bundle that runs down to the front of the car.
#6 Eddy029
Eddy029
  • 24 posts
Posted 15 December 2011 - 06:24 PM
To clear things up: Main beam works perfectly. It has NOT been bodged together, all I have done is take a supply from ONE of the blue/white wires for the relay. All connections are insulated and crimped, not just twisted together and held with insulation tape which is what you seem to be insinuating. I looked on this forum and researched in great depth as to which wires to use so I didn't end up with a smoldering Mini shell. Like I have already said, I tried the blue/white wire that was pictured in a topic on here behind the grill and it was dead. I tested it with a Multimeter and there was no power showing, so I thought I'd trace the wiring back and try and find somewhere else to get a supply. How is this a bodge? I don't like how people suddenly jump to conclusions...
Anyway, I've just been to check that the relays all wired up properly and it is, the main thing I want to know at the moment is why there's 2 blue/white wires? Is one for main beam when you flick the stalk forward and the other for when you flick it back and want them on all the time?
#7 1984mini25
1984mini25
  • 8,784 posts
Posted 15 December 2011 - 06:25 PM
Read above
#8 lrostoke
lrostoke
  • 6,923 posts
Posted 15 December 2011 - 06:27 PM
what years the car ??
maybe its been rewired , possible a break in the original blue/white and somebody ran a new one down.
#9 Eddy029
Eddy029
  • 24 posts
Posted 15 December 2011 - 06:41 PM
Read above
And I said, my main beam is still working perfectly. I still fail to see what is wrong with snipping a wire and taking a feed out for a relay, ensuring the new connection is fully insulated? If I had bodged it, I would have snipped the wire, taken a feed and just wired it straight up the the spotlights without using a relay. I thought I was doing the right thing, obviously not.
Its a 1994 Cooper, and I'm starting to think it might have a break somewhere on that wire, it did have some work done on the wings and front end so maybe a wire was accidentally nipped or something...
#10 lrostoke
lrostoke
  • 6,923 posts
Posted 15 December 2011 - 06:43 PM
Blue/whites should be high beam circuit, suprised on a 1994 there isn't already wiring in place for spot lights. I know on my brothers old 1993 Cooper is had the wiring there as standard. Or are these additional ones ??
#11 Eddy029
Eddy029
  • 24 posts
Posted 15 December 2011 - 06:57 PM
Well I looked on here and saw that there was a bullet connector on the end of a wire behind the grille, had a look and thought 'Great, I can use that, this should be simple.' But there's no power going down it, so I thought I would try and tap in a bit further up the loom. I have added these spotlights myself, it didn't have any when I bought it and I don't think its had any from new as there were no holes for the mounting brackets. I assume the bullet connector was the original wire for the optional spotlights.
#12 lrostoke
lrostoke
  • 6,923 posts
Posted 15 December 2011 - 07:01 PM
seeing as you have a multimeter I'd run the following test
The blue/white you tapped into. connect the meter to it see if it goes on and off when you select high beam.
If it does then should be no problem using that as the switching feed for your relay
Where are you taking the main 12v feed from
where are you earthing the relay ??
#13 Eddy029
Eddy029
  • 24 posts
Posted 15 December 2011 - 07:08 PM
Cheers, I'll do that test tomorrow when I have time.
Main 12v feed is taken straight from the battery, and yes it is fused.
Its earthed to the bracket where the immobiliser is, well I think its the immobiliser.
