Oil Gallery Plugs...
12 replies to this topic
#1 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 15 December 2011 - 09:17 PM
Hi...I've been replacing the core plugs and oil gallery plugs on my engine...the core plugs went in no problems but the oil gallery plugs seem to be a bit loose...I pressed them in untill they went tight but they are a long way into the holes. Way further than the old ones I took out. Are there different types or sizes?
#2 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 15 December 2011 - 09:25 PM
I am not familiar with the sizes involved but I remember that when I worked on my engine I tapped the holes and fitted them with threaded pipe plugs.
#3 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 15 December 2011 - 09:40 PM
Oh! I didnt know you got threaded ones...thats a good idea...but its a bit late now..Im just a bit worried that they might pop out. Does anyone know if they come in different sizes..maybe ive fitted the wrong ones..
#4 Cooperman
  • 23,286 posts
Posted 15 December 2011 - 09:52 PM
The pressed type can be a problem if the holes are a bit oversize. I had one leak once.
If you can get hold of some of the old solid tapered ones they are better. I'm thinking of getting some turned up in brass, but just haven't got around to it yet.
I've used 'Loctite Bearing Lock' on some that have seemed a little loose and that seems to work fine.
The current pressed ones are a bit 'cheap & nasty'. Typical later Rover in fact.
#5 sledgehammer
sledgehammer
  • 3,098 posts
Posted 15 December 2011 - 10:03 PM
I think you need to locktite them in
http://www.ukclassic...-brass-plug.asp
that is the only info I can find on them so I should imagine they are all the same size
personally I have got mine tapped locktited & plugged with a Allen grub screw's
& gallery's flushed
#6 charliedurrant
charliedurrant
  • 519 posts
  • Local Club: There isn't one down my way
Posted 15 December 2011 - 10:29 PM
Hi,
It's already been said but I know that Bob Sollis (Miglia racer) has them tapped as Doug has said.
Charlie
#7 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 15 December 2011 - 11:23 PM
Thanks guys... looks like im going to have to take it all apart again and get them tapped...Oh well, live and learn...
#8 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 16 December 2011 - 08:22 AM
I found the same problem this time,but 18 months ago I did another and they were perfect so there is perhaps a bad batch around. Minispares? I use Loxxeal which is an LPG assembly seal/locking compond also for steam and oil and higher temp's. That wont let go!! but as you say,a little further in and they are tighter.
Edited by PIGEONTO, 16 December 2011 - 08:23 AM.
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 16 December 2011 - 08:28 AM
If you going to tap them, make sure you thoroughly wash out the oil galleries before putting in the grub screws.. last thing you want is a little bit of swarf hiding in there...
and while thinking ahead... good place to tap one for an oil temp sender..
Edited by Guess-Works.com, 16 December 2011 - 08:29 AM.
#10 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 16 December 2011 - 02:29 PM
Good thinking...Your cup is always half full eh John!!
#11 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 04 January 2012 - 11:01 PM
I thought I would add to this post rather than start another, hope the OP doesn't mind.
I have managed to remove the oil gallery plugs from my block (std A) which were the solid brass type.
Drilled & tapped
Bolt, washers & spacer
Four plugs out clean
My question is regarding the replacement. I've read / seen that tapping & fitting a threaded plug is the best option? I'm sure one I read suggested that the same threaded plug as used in the inlet manifold where there is no servo could be used.
Any suggestions / recommendations welcomed, and if anyone has a drill / tap / thread spec, that would be superb
Thanks in advance
Steve
#12 icklemini
icklemini
  • 2,982 posts
Posted 04 January 2012 - 11:09 PM
never needed to faf around with drilling and tapping...
loctite some new ones in - job done... if you are worried they are still gonna pop out then stake the sides of the hole with a chisel....
#13 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 04 January 2012 - 11:53 PM
The servo hose connections I have seen are fairly large, much larger than the gallery plugs I replaced with pipe plugs. From what I remember I used a combination of 1/8 NPT and 1/4 NPT plugs as necessary.
