Split Brake Pipe Need Help
Posted 16 December 2011 - 07:45 PM
Posted 16 December 2011 - 07:51 PM
Posted 16 December 2011 - 07:54 PM
Posted 16 December 2011 - 07:59 PM
Edited by bmcecosse, 16 December 2011 - 08:01 PM.
Posted 16 December 2011 - 08:01 PM
Posted 16 December 2011 - 08:04 PM
Posted 16 December 2011 - 08:12 PM
Posted 16 December 2011 - 08:13 PM
And 'copper' is not mentioned - so don't use copper!!
hehe okey dokey
Posted 16 December 2011 - 08:44 PM
As stated above, Kunifer (copper-nickel) is the right stuff. You can tell the difference between that and copper, because it is not quite so red in colour. But it is not as tolerant of fatigue as steel (bundy), so must be well clipped down.
With a rubber mounted subframe, personally I would prefer bundy in the runs from the master cylinder to the front subframe to avoid fatigue problems due to subframe movement. Or, a short flexible hose could be fitted. Same at the rear subframe, although there is usually a large loop at the pressure limiter, which should accomodate some minor movement without problems.
Everywhere else on a Mini, the pipes should not be flexing, and Kunifer will last longer than the rest of the car. Bundy is only good for a few years.
One thing to avoid is the plastic coated bundy pipe used on some vehicles. I had it on my old Talbot Express van. Quite predictably, minor damage causes pinholes in the coating, corrosion sets in and a pinhole develops in the pipe.
Posted 16 December 2011 - 08:52 PM
Posted 16 December 2011 - 09:01 PM
I totally agree, but not everyone will want to do it, mostly because of the extra noise. But it does not cost a lot and seems to improve the handling almost as much as spending serious money on fancy suspension bits.
Posted 16 December 2011 - 09:02 PM
Just because it is sold by Minispares, it does not follow that it is safe or legal. I am very disappointed that they are selling copper brake pipes.
Posted 16 December 2011 - 09:12 PM
Plain copper pipes corrode badly and split whereas the copper-nickel pipe doesnt (or at least not for a very long time in which case it would be picked up on an MOT)
Edited by nafnaforiginal12, 16 December 2011 - 09:14 PM.
