Servo Brakes Conversion
9 replies to this topic
#1 fredsat
fredsat
  • 10 posts
Posted 16 December 2011 - 08:04 PM
Has anyone got any photos / info on how the best way to go about a servo brakes conversion
I have a 1984 Mini City with no servo i am fitting a bigger 1300 engine in to it and think i better do something with the brakes
The mini is under going a complete strip down and rebuild so i am hoping to do this job well the car is striped
Many thanks
#2 bmcecosse
bmcecosse
  • 9,699 posts
Posted 16 December 2011 - 08:10 PM
Mini is a small light vehicle - it does NOT need a silly servo!! Just fix the brakes......
#3 Magic jason
Magic jason
  • 522 posts
Posted 16 December 2011 - 08:12 PM
agreed with BMC, i have no problems not having a servo!
#4 Kerrin
Kerrin
  • 1,056 posts
  • Local Club: Manx Mini Register
Posted 17 December 2011 - 10:21 AM
It's quite a bit of work to change to the later servo system, as you need to change the pedal box assembly, master cylinder and the rusty steel plate under the master cylinders to a different type. Basically it would be better to strip all the bits out of a later mini.
My car is 1380 and non servo with alloy 4 pots. The standard disks and calipers are just as good though. Just make sure the brakes are all in good order and press harder if required.
It also saves cluttering up your engine bay with the big servo unit.
#5 jagman.2003
jagman.2003
  • 1,307 posts
  • Local Club: Owner of my own club of Minis
Posted 17 December 2011 - 10:36 AM
But if you really want a servo you can always buy the remote servo kit from minispares/minisport. You will need the larger master cylinder too of your adding the disc brakes & replacing drums. I personally prefer the servo. Maybe because I drive a modern car most of the time & am used to have instant brake response.
#6 MJWarren
MJWarren
  • 705 posts
  • Local Club: DCMOC
Posted 17 December 2011 - 11:29 AM
I run a single line system, with Cooper s discs and calipers with a cooper s servo on the front brakes only. As an experiement i disconnected the servo to see what difference it made and the brakes were useless. Cooper s servo is a 1.9:1 servo so effectively your applying double force.
It doesnt Clutter up space if you fit it under the dash board.
#7 mike.
mike.
  • 6,176 posts
Posted 17 December 2011 - 11:36 AM
I thought servo's just do the work for you so you don't have to use so much force on the pedal. They don't increase brake power do they?
#8 MJWarren
MJWarren
  • 705 posts
  • Local Club: DCMOC
Posted 17 December 2011 - 01:53 PM
#9 Frisco
Frisco
  • 417 posts
Posted 17 December 2011 - 03:18 PM
For all we know the OP has a bad leg, knee, hip, foot or whatever and not having to push as hard on the pedal would help. A servo helps no matter how light the car is and I dont see the problem in fitting one if its wanted.
#10 fredsat
fredsat
  • 10 posts
Posted 17 December 2011 - 04:02 PM
Many thanks i will leave them as they are willjust look at 4 pots and new brake pipes all round
Thanks all
