Is My Engine Leaded Or Unleaded
Posted 19 December 2011 - 08:04 PM
i have a rover mini mayfair auto 1985..998cc.. how do i no if its leaded or unleaded..
thanks
mohammed
Posted 19 December 2011 - 08:07 PM
I use an additive.
Posted 19 December 2011 - 08:16 PM
Posted 19 December 2011 - 08:22 PM
But it could be unleaded if someone has changed the head to a unleaded one.
Posted 19 December 2011 - 08:24 PM
Posted 19 December 2011 - 08:28 PM
Guide to Engine Numbers
Eventually i'll build this into a guide to Mini and Metro engine numbers. Telling you what they mean, how they break down and which mini's and Metro's have equivalent engines.
So far though here's a list of engine number prefix's which are compatible with unleaded petrol. It is only the head that is different, so you can use this information to source unleaded heads from breakers for your mini.
Here is a list of unleaded engine numbers for the 998cc engines.
99HF15, 99HF32, 99HG30, 99HG31, 99HG32, 99HG33, 99HG34, 99HG39, 99H/D81P, 99H/E20, 99H/E21, 99H/E22, 99H/F16.
All the post 1990 1275 mini engines are unleaded compatible, many of them have CATs so can only use unleaded. None of the pre 89 engines, or sizes other than 998 and 1275 can use unleaded, with out modification. Information Received from Barrett''s MG-Rover, Folkestone.
Edited by firefox, 19 December 2011 - 08:38 PM.
Posted 19 December 2011 - 08:59 PM
Posted 19 December 2011 - 09:28 PM
Posted 19 December 2011 - 10:03 PM
you should put your engine number into guess works engine checker to find out more about it.
Posted 19 December 2011 - 10:10 PM
eeae6000, you should search for something called lead memory, as if you're car is leaded, it's information you will want to know.
Posted 20 December 2011 - 01:32 AM
1989 unleaded
is this why my 1985 998 works without modification?
Edited by Huddley_Clubby, 20 December 2011 - 01:33 AM.
Posted 20 December 2011 - 02:29 AM
I think you're interpreting what that says incorrectly.
1989 unleaded
If your cylinder head has not been converted to unleaded using hardened valve seats then you are running on a lead memory in the seats. Once that memory wears off, your valves will start eating in to your head.
Posted 20 December 2011 - 08:20 AM
Posted 20 December 2011 - 10:54 AM
It is not your "engine" that is leaded or unleaded. It is your cylinder head.
Therefore look at your cylinder head casting number.
Because BL used so many different heads for so long the engine number does not really tell us anything. This also only tells us how is LEFT the factory and not what it is now
Sorry for the attitude but you will need your head casting no. to be sure. (Its under the rocker cover in the middle under the rocker shaft.
Jesus
Posted 20 December 2011 - 11:09 AM
This is all ridiculous.
Jesus
I'm afraid that at some point you've been seriously misguided...
The engine number tells you exactly the specification of the engine as it left the factory, ok, some of the information has been lost over time, especially information from the 70's, however, 80's onwards is very well documented...
The casting number on the head means very little, ie all 1275 heads post cooper S are 12G940 castings, whether it be from a GT, turbo, spi, Metro, unleaded or leaded, and the same is true for 998 and 1098 A+ heads which are CAM4180 castings, irrespective of their specification.
