Beetle Wheels On A Mini
Posted 20 December 2011 - 10:12 AM
So I wondered, how hard would it be?
Posted 20 December 2011 - 10:21 AM
Edited by leaky, 20 December 2011 - 10:21 AM.
Posted 20 December 2011 - 10:25 AM
Posted 20 December 2011 - 10:26 AM
Posted 20 December 2011 - 10:40 AM
Posted 20 December 2011 - 11:43 AM
Posted 20 December 2011 - 12:13 PM
Posted 20 December 2011 - 12:34 PM
I should also add its IMP wheels you would need. They come in 12" and you can fit the chrome hub caps to those.
Sorry, I'm guessing this is a very nooby question, but what do you mean by IMP wheels?
Posted 20 December 2011 - 12:42 PM
Would be easy enough to put them on. But beetle wheels are 15" and would look way to big on a mini IMO
It would not remotely be easy, regardless of the size! Beetle wheels use a 4 x 130 pcd fitment, the studs would be very close to the edges of the driving flange if they fit inside it at all. You would need completely custom drive flanges.
Imp wheels are wheels for a Hilman Imp.
Posted 20 December 2011 - 12:50 PM
Meenwhile, I am going to try and contact a Japanese company who stock them, see how much I can get the shipped over for, if they have them in stock...
Posted 20 December 2011 - 12:51 PM
the fitting hole's are larger to use 7/16 unf wheel nuts ,
mini 3/8 unf the standard mini wheel nut will only locate on a small area of the wheel and will keep working loose,
been there done that lucky only need new wing to repair.
john
Posted 20 December 2011 - 12:58 PM
it's only the late beetle wheels that are 4 stud [68 on] most are 5 stud 5x205 PCD about the same as a late minis disk
Posted 20 December 2011 - 01:02 PM
hi all
john
So would you not recommend using them? Or are you saying I need to buy larger wheel nuts if I use them?
Posted 20 December 2011 - 01:13 PM
Bungle, I had a feeling older Beetles were 5 stud but couldn't remember any numbers. 205 is even worse though, as you say it'll never fit.
Posted 20 December 2011 - 01:18 PM
