Noobie With A Mini 1000
9 replies to this topic
#1 AC&SONS
AC&SONS
  • 127 posts
Posted 22 December 2011 - 09:35 PM
My son is coming up to his 17th birthday next year, and after previously being set on having an Aygo/C1/107 for his first car, he was getting insurance quotes of over £3k :ohno: I owned a 998 and then a 1275GT in my earlier years so I knew my way around Minis, which meant it seemed logical to buy one for his first car.
We started hunting, initially for Coopers, before I found out that it would cost £1500 more for insurance on a 1275cc compared to a 998! It was then that I stumbled across this blue 1000: http://www.ebay.co.u...9#ht_500wt_1202
Admittedly, it was older than I was really looking for being a 1977 car, but it had been owned by the same family since new and had only done 40,000 miles. It had a brand new front end and A-panels, as well as a newer (less brown) interior and front brake discs in 2007, and rust-wise there was hardly anything to report. On the test drive it ran brilliantly and after looking at three other cars, this one was definitely the best and the one I really wanted.
Here is a pic from the advert: Posted Image
We drove the 75-mile journey home and the car never missed a beat, although we thought that, even though the engine only originally had 40bhp, by cleaning it and freshening everything up it could feel a bit more sprightly. There was no doubt that it was in brilliant condition for its age, but we knew that there was more room for improvement.
The first thing we did was have all the wheels off and rustproofed under the wheelarches and in the sills, before painting it all black.
Before: Posted Image
After: Posted Image
We also detailed the wheels (he wants some new centre caps for these as well)
The underneath of the car was also rustproofed whilst the exhaust was re-painted:
After this, we set to work on the interior. We removed the seats and carpets (and underfelt!) which revealed a reassuringly solid shell. This was then cleaned and any surface rust was treated and painted with Hammerite. We then removed the dashboard and soundproofing and new soundproofing has been installed (not shown on this photo).
The interior has been left like that for the time being until I get a new radio and all the speaker wires must go under the floor, so then it was time to tackle the engine bay. It was probably the weak point of the car because it was very grubby and needed a thorough clean, so we decided to remove the engine.
The engine as it was before removal:
Hung on the hoist!
The engine was then placed in front of the car so that we could begin grinding off surface rust and dirt. The results were very surprising - even before painting, it was looking quite shiny!
The block was then painted black, with the rest including the cylinder head silver. I plan to get a blue rocker cover which should be added in the next week or two. Here is the engine now:
Meanwhile, the gaping hole in the engine bay meant that we could re-paint the bulkhead and all exposed metal the original blue it once was. Surface rust was removed and then it was sprayed with grey primer before the blue was added on top. We also painted the subframe with black Hammerite.
Here is a collection of bits that were taken off the engine before removal which have also been cleaned where necessary and sprayed black/silver:
That is the stage that we are currently at. There are only a few more jobs to do before the new year when the engine and interior will be going back in. I will keep this thread updated as things progress.
Thanks for looking :)
#2 mk1leg
mk1leg
  • 9,343 posts
Posted 22 December 2011 - 09:54 PM
Hi..and welcome to TMF and enjoy..................nice job on the engine bay.................. :proud:
#3 MaxAndPaddy
MaxAndPaddy
    Spamela Anderson
  • 4,700 posts
  • Name: Elvis
Posted 22 December 2011 - 09:59 PM
Hi and welcome to TMF!!...Gorgeous car!!
Hes a lucky lad
#4 conlad
conlad
    Previously known as ct16mini.
  • 2,054 posts
  • Local Club: Hilltop Minis
Posted 22 December 2011 - 10:28 PM
You didnt pay 4k for that did you? O_O
#5 AC&SONS
AC&SONS
  • 127 posts
Posted 23 December 2011 - 07:55 AM
No, we got it for less than that because the seller must have realised that the starting bid was quite high!
#6 conlad
conlad
  • 2,054 posts
Posted 23 December 2011 - 09:11 AM
Was gonna say mate! Haha good stuff, looks very very tidy!
#7 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 23 December 2011 - 11:26 AM
Are those what I think they are!!! :ohno:
They certainly look like those screw on wheel stud extensions for use with a spacer. If so they can be absolutely lethal a they have a nasty habit of shearing through. I'm amazed that they are even legal in this day and age!! If it were my sons car, I would be replacing them with the proper rear drums with a built in spacer and longer wheel studs, as was fitted to the later models as standard:
Drum: http://www.minispare...id=35841&title=
Studs: http://www.minispare...id=36224&title=
If you don't want to buy new drums, then at the very least fit some extra long studs and throw those things you've got there away!!
Edited by AVV IT, 23 December 2011 - 11:28 AM.
#8 AC&SONS
AC&SONS
  • 127 posts
Posted 23 December 2011 - 12:33 PM
Thanks for the advice, I will order some new drums and studs - like you I don't want my son to be driving something that is unsafe! This is why I joined TMF, for this great guidance - I would never have known had you not alerted me to it! :o
Any more tips or hints?! :thumbsup:
#9 AC&SONS
AC&SONS
  • 127 posts
Posted 22 January 2012 - 07:05 PM
An update:
Got a lot of things done in the past few weeks - the Mini is now fully back together and running perfectly!
First thing was to get the engine back in and running. We knew that getting the driveshafts back in would be the most difficult part, although actually it was less trouble than we expected.
Straight after the hoist was removed:
We then added the blue rocker cover which set the engine bay off nicely:
It took a bit of cranking which we expected, but once a tight throttle cable had been sorted, it was running brilliantly.
All the grilles were then put back on - I got a new grille surround kit from Mini Spares which we fitted and then the front was done.
After an earlier post from AVV IT alerting me to the spacers on the rear drums, I bought some new ones from Mini Spares with the built-in spacers which are apparently a lot safer:
The headlining had orange patches all over it and looked like something had been stuck to it at one time, so we used some white primer and sprayed it, which avoided the big task of fitting a new headlining.
The rear speakers were installed in the parcel shelf - I didn't realise they were so small when I bought them but they had good reviews and it's only a small car so they should be adequate. The radio should be in and working next weekend.
All the interior was then completed, and we have added a new dash liner, rev-counter and steering wheel adjuster, as well as the radio and cigarette lighter which are now fully installed.
I also wanted a boot liner, but I wasn't prepared to pay the ridiculous prices at Mini Spares, so we made one instead by cutting some wood and sticking my old bedroom carpet on it :lol: I was very happy with the result.
Before:
After (apologies for the quality):
Mudflaps are also now on the back, as well as a subtle piece of chrome trim I got from Halfrauds to cover up the sharp edge which runs along the front and rear valance. Chrome exhaust trim has also been attached after this photo was taken.
We're going to Bingley Hall next week where I'm sure he will see some bits and pieces to add to it - he already wants some chrome door handles and window winders and some new centre caps for the wheels!
We are now in the process of detailing the paintwork - I will post some pics of the results soon :proud:
Thanks for looking
#10 Weeemaan1985
Weeemaan1985
    Starting My Mini Up
  • 2 posts
Posted 23 January 2012 - 08:44 PM
Very nice mini mate
