Starter Motor Wire Snapped Off, Which One Is It!
Posted 24 December 2011 - 08:35 AM
One of my wires burnt out and burnt through a few of my other wires. My problem is that one of the wires to my starter motor has now disappeared and I can't seem to trace it! I have replaced all the other wires.
It's the wire that sits at the back nearest the engine on the starter motor. What does it do and where can a trace it?
If anyone has any wiring diagrams or info that would help! Thanks
Posted 24 December 2011 - 08:42 AM
It should be brown/red and comes from a relay up near the bulkhead
The relay will probably have
brown wire
brown/red
black
white/red
There is another terminal and if I've mixed the 2 up it will be the ballast byepass, and is white/yellow and goes to the positive on the coil.
Edited by lrostoke, 24 December 2011 - 08:48 AM.
Posted 24 December 2011 - 08:49 AM
Posted 24 December 2011 - 09:03 AM
The white/yellow isn't needed with megajolt.
Posted 24 December 2011 - 09:06 AM
Posted 24 December 2011 - 09:08 AM
Posted 26 December 2011 - 09:43 AM
Would normally have a white/yellow wire on it. But you megajolt doesn't need it
Doesn't explain the no power though because that terminal is only live when the starter engages
Edited by lrostoke, 26 December 2011 - 09:44 AM.
Posted 26 December 2011 - 09:54 AM
Will also check on the battery!
Posted 26 December 2011 - 09:59 AM
Browns are 12v perminant lives,
So ceck all your battery connections and earth connections and any browns
Posted 26 December 2011 - 05:48 PM
Thanks for all your help though!
