***Turbo Flames!***
Posted 11 February 2006 - 04:11 PM
would it be possible to take the return pipe and attach it to the exhaust manifold? Without burning the car down? lol
Posted 11 February 2006 - 04:19 PM
Posted 11 February 2006 - 04:20 PM
Posted 11 February 2006 - 04:24 PM
It pays to be creative sometimes
Posted 11 February 2006 - 04:55 PM
Im just thinking back to the 80's when you would see a Quattro with huge flames comeing from the back, and it looks impresive, How would this be achived in a mini, I thought somehow of making the Return Fuel pipe flow into the Hot exhaust and flames would be achived
Havent tried it, thats why i asked u guys 1st:D
Posted 11 February 2006 - 04:58 PM
then you have a switch inside the car which switches off the normal coil and the other one on.
unburnt fuel then travels down the exhaust and is set alight by the "flamer" spark plug.
This is called a flamer kit.
thats roughly the way it works i think.
Posted 11 February 2006 - 05:00 PM
Posted 11 February 2006 - 05:03 PM
I don't see why people attempt to recreate this on a road car, flamer kits are IMHO a stupid idea! NO NEED!
And as for attaching a fuel return pipe to a source of ignition???? NOOOOOOOOOO!
Posted 11 February 2006 - 05:11 PM
When you see flames coming out the back of a rally car, it is not done on purpose
I know about this its the ALS right?and that why it keeps banging & popping.
i think what you are meant to do is put a spark plug near the back of the exhaust attached to a seperate coil.
Ive heared about this, but i dont want just a flame, id like when id change down it would be popping and backfiring, Havent had a mini turbo before would anyone know if this happens anyway
Posted 11 February 2006 - 05:15 PM
Posted 11 February 2006 - 05:21 PM
Posted 11 February 2006 - 06:11 PM
got the carbs and timing setup and its gone away now.
Posted 11 February 2006 - 10:21 PM
It was due to the fact i removed the dumpvalve and instead of the compressed air being released through the dumpvalve it had no other choice than to exit at the air filter.In doing this the AFM (air flow meter) senses the air passing through it but doesnt know the difference with it coming in or out so thinks it is sucking in a load of air and hence dumps in a load of fuel in which is just flushed out the exhaust and if the exhaust is hot enough combusts and causes load pops and flames.
I think that is one of the reasons Fuel injected cars anyway have dump valvs fitted as standard as with out it u run a chance of running too rich and failing MOT's and emissions........ or so i was led to believe.
Dan
