***Turbo Flames!***
#16
Posted 12 February 2006 - 12:40 AM
#17
Posted 12 February 2006 - 10:16 AM
And you loose the steering when turning the engine off?? Only with power steering! Which most minis never had anyway! You don't loose any of these functions with the engine off, even if you have a brake servo. You only loose the aid of the servo, so you can still turn the wheels and brake, only you'll need more effort than before.
And if your the type of person who likes to see flames sprout from your exhuast for the fun of it, then your the type of person that should be asking mummy to go put the matches somewhere you can't reach them!
#18
Posted 12 February 2006 - 10:25 AM
Go to local takeaway,
Order Vindaloo,
Wait for 2 hours,
Hold lighter near to rectum and wait for the anti lag system to kick in!
That would be a whole lot safer and would also not risk damaging a perfectly good mini (unless you were sat in it at the time)!!!!
#19
Posted 12 February 2006 - 11:53 AM
Well most of that was rubbish. I highly doubt the ability to make a 6ft flame by turning your engine off and on while moving, yes it will cause a lot of unburnt fuel to be pushed straight through the engine and into the exhuast, but a 6ft flame? No!
firstly i said i wouldnt try this. secondly i said you can loose a lot of a cars functions not you will. thirdly i also said i wouldnt do this. i myself dont have a servo as i think they are a waste of time (for me anyways) i would prefer the extra space in the engine bay. I was only saying what i had read on a forum (i forget which one it may have been on here ). i am not here to argue. but it seems to me that you are at every opportunity. this is all i am going to say as i will not waste anymore bandwidth with petty arguments
#20
Posted 12 February 2006 - 12:00 PM
You can't loose brakes and steering just from turning off the engine on a mini. Its not even a maybe.
#21
Posted 12 February 2006 - 12:01 PM
(oh and by the way i did get a pretty serious telling off by the RAF police sergent, he did find the funny side of me back firing the landy as i drove past the main gate and make my mate C**p him self whilst on guard duty.)
#22
Posted 12 February 2006 - 12:14 PM
you can if you turn the key to far and the stearing lock comes on
#23
Posted 12 February 2006 - 06:21 PM
#24
Posted 13 February 2006 - 09:17 AM
have the mini run rich at idle, take it for a nice foot to floor every-where drive
by the way works soooooo much better if you loosen your front c-clamp on you lcb system
ok also try this remove your vacuum advance pipe
#25
Posted 14 February 2006 - 12:47 PM
oh and the steering lock wont come on as the keys will still be in the ignition!
maybe thats because i ent got a steering lock, well it never works anyhow!
#26
Posted 20 February 2006 - 02:16 PM
Personaly i would build a high performance engine and it will probably do it anyway and lets face it, its a bit sad pretending to have a fast car??
#27
Posted 20 February 2006 - 06:50 PM
#28
Posted 25 February 2006 - 11:33 PM
Right to quell a few arguments............
DONT put the return hose to the exhaust unless you want a fireball as a car! the pressure regulator 'regulates' the pressure going to the carb. the fuel pump supplies a pressure and flowgreater than needed so therefore there is always fuel returning through the line, not good at all if routed to the exhaust!!
Flames from turbocharged rally cars......
this is created by the Anti Lag System. this works by changing the ignition timing during let off. when the throttle is closed the timing is retarded greatly so that the sparc occours when the exhaust valve is open, thus the ignition stroke of the engine happens in the exhaust manifold. the expansion of the gasses spin up the turbo so as to reduce the lag. Simple if you know how!! Dont try this at home boys and girls. this 'explosion' in the exhaust manifold can blow it to bits if it is not up to the job!!
Just on a seperate note, the dump valves mentioned are to reduce lag also. the expell the pressurised air between the butterfly ant the compressor side of the turbo to stop the pressure wave from traveling back up the intake and stalling the spindle.
As for flames fron N/A cars. (race and highly tuned) this is due to the high overlaps in cam timing. at lower rpms there is sufficiewnt time for a fair bit of intake charge to flow into the chamber and then back out through the exhaust. when this un-burnt charge comes into contact with, usually if you have tried hard enough, a cherry red exhaust it will ignite and flow down the exhaust til it reaches the end. Exit one flame!
As for some peoples explanations of getting flames and 'pops' from the engine, ooh deary me, i really do feel sorry for your engines!! not healthy suggestions at all!!
Bit af a ramble there!! End of Lecture!
#29
Posted 26 February 2006 - 12:13 AM
Just brousing the forum and came across this thread. Dear dear how some of you are dis-illusioned!! (Cand believe i registered just to reply!! Ah well, boredom for you!!)
Have to agree with what has been said above. However, to the guy with the 200SX, please do prey tell how the hell compressed air produced by the turbo charger, would release though the side of the turbocharger that draws it in. Is there a magic door that only 200 SX owners know about that a bar of boost can make a quick exit from? What you would of heard is commonly referred to as waste gate chatter (although it actually isn't, that just the "cool" way to describe it!!) becuase you had removed the standard relief valve. When you release the throttle after being on boost, where does the built pressure go? nowhere, it stalls the turbocharger which is your "waste gate chatter" You hear it though the filter becuase you are stalling both sides of the compressor, there is no air escaping as such!! However, I have seen it first hand on a calibra where some really clever person tried this, and it actually snapped the turbine wheel shaft.
As for the dump valves.. depending on management, some cars do not like the classic diaphragm style of dump valve (bosch motronic 2.8 a prime example, calibra/cavalier turbo) and yes the airflow meter is one of the factors, but not the only factor, but as a rule of thumb, a normal bailey or similar piston dumpvalve does absolutely no harm at all, let alone mess around with the airflow meter as described.
carry on.....
I think that is one of the reasons Fuel injected cars anyway have dump valvs fitted as standard as with out it u run a chance of running too rich and failing MOT's and emissions........ or so i was led to believe.
Dan
sorry, but to sprout something like that you must have been dropped on your head at birth.. do you mean to imply if a vehicle is fuel injected, it has a dumpvalve?
does that mean my diesel cement mixer has one?
#30
Posted 26 February 2006 - 09:25 AM
...............does that mean my diesel cement mixer has one?
LMAO!!!!
