Can You Weld Stainless Steel To Mild Steel?
7 replies to this topic
#1 mister bridger
mister bridger
  • 911 posts
Posted 29 December 2011 - 01:35 PM
I'm making a tool to remove the castellated ring nut thingy that holds the hub on, on my old Lancia. I've made a piece to fit the nut from a stainless steel disc about half an inch thick I had lying about and I need to weld a 3/4" hollow mild steel bar to it. It must be good and strong as these things are on VERY tight. I have a normal mig welder and an arc welder. Any tips?
#2 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,147 posts
  • Name: Sean
Posted 29 December 2011 - 01:38 PM
Not usually a great sucess, but you could use some dissimilar rods for the arc welder. They usually glue most stuff together.
#3 Shifty
Shifty
  • 13,147 posts
  • Name: Sean
Posted 29 December 2011 - 01:39 PM
http://www.thewelder..._Pack_29_9.html
#4 Carlzilla
Carlzilla
  • 1,907 posts
  • Local Club: Splinters Mini Club
Posted 29 December 2011 - 01:44 PM
Theres a bit about it on the mig welding forums chap, most seem to prefer using 312 stainless rods with an arc welder it seems!
Edited by Carlzilla, 29 December 2011 - 01:45 PM.
#5 Globule
Globule
  • 1,134 posts
Posted 29 December 2011 - 02:06 PM
What grade of stainless is it? I've welded 430 and 304 to mild steel before (using a MIG) and never had any problems, but it wasn't subject to as concentrated force as you would be.
#6 mister bridger
mister bridger
  • 911 posts
Posted 29 December 2011 - 02:11 PM
Cheers, Shifty. At £35 or more for a pack I think I'll take it to my local Ironworkers after the xmas break and get it done by people who will do it right first time!
#7 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 29 December 2011 - 02:41 PM
I've made various tools and things using a mixture of stainless and mild. Never had any problem with strength or penetration. (using mig and arc)
Would never attempt to weld stainless and mild body panels together though
#8 mininuts
mininuts
  • 1,645 posts
  • Local Club: Mini Clan
Posted 29 December 2011 - 05:21 PM
You can weld stainless and mild steel together with no issues at all with the correct wire or rods, we do it every day.
I'd suggest you take it to a local fabrication/plating workshop where they'll probably have to right wire or/and rods to put a proper weld on your tool :shy:
Shame you're so far away, I'd have done it you for nowt.
