What's different about a 1275 metro hle engine? I think they have a 3.1 diff but what about the compression ratio, any different?
Ta, Josh.
Metro Hle Engine
MiniJosh92
, Dec 29 2011 06:19 PM
4 replies to this topic
Posted 29 December 2011 - 06:19 PM
Posted 29 December 2011 - 06:54 PM
Ta, Josh.
Gearbox has a specific gear set with different ratios, identifiable with a double notch on the gear teeth, instead of the single notch found on all standard A+ gear sets
Posted 29 December 2011 - 07:01 PM
Yes its the wide ratio gear set thats in the HLE gearbox, Also the input gear is the economy one. 3.1 FD..cruises at much lower revs but is not so quick on acceleration.. I have just removed it from my car and gone back to the standard ratios and 3.44 FD...I was bored..
Posted 29 December 2011 - 07:07 PM
Also runs an overdrive set of drop gears...
But, from an engine perspective, there's very little difference between that and any other metro engine.
Posted 29 December 2011 - 08:47 PM
