Gianni Potenza 7X10 Wheels?
14 replies to this topic
#1 mt2man
mt2man
  • 149 posts
  • Local Club: PandSMOC
Posted 29 December 2011 - 10:23 PM
Just wondered if anyone on here had a set of them?! Im interested in getting some, i hear they have very wide offset so they may clear my metro 4 pots?!
These arent my pictures so i hope whos ever they are doesnt mind me showing them , but they are gorgeous!
I have these arches and they would be fitted to an Estate :)
This shows the offset but im not sure if they will fit metro brakes?
Thanks Jack
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 29 December 2011 - 10:25 PM
just check the weight rating when fitting golf cart wheels to a mini
and you can't buy a road tyre for a 7x10 wheel
Edited by Bungle, 29 December 2011 - 10:25 PM.
#3 mt2man
mt2man
  • 149 posts
Posted 29 December 2011 - 10:57 PM
I wasnt asking about golf cart wheels, Gianni Potenza alloys are road legal. There are copies of them built for golf carts which may not have passed tests to make them legal but im pretty sure they are most probably built in the same factory and are just labelled differently after haha.
And tyres can be fitted to them, they may not be 7" wide but they can be fitted without too much of a stretch.
But thanks for your concern!
My main concern is if they will actually fit over my brakes.
#4 Tupers
Tupers
  • 4,158 posts
Posted 29 December 2011 - 11:03 PM
Looking at that picture I doubt it. Every 8.4" vented disc and 10" wheels combo I've seen ends up with the wheels sat almost beside the calliper not over it.
It's also worth notting that Yokohama don't recommend you run those tyres on anything wider than a 6" rim so if you do have a crash and the insurance company digs they could avoid your policy.
#5 mt2man
mt2man
  • 149 posts
Posted 29 December 2011 - 11:10 PM
Yeah that was my main worry, i have some 10" MAG superlights and even with 1" spacers they still wont fit so looking for some other 10" wheels that may work, ive seen Wellers fit and i beleived this was because of the wide offset, these also have a wide offset so was hoping for the best. Its not looking promising though.
And that is a fair comment to make regarding the tyres, but there are many people who run 10" wheels that are wider than 6" so there must be a way around that, surely?
#6 Ivor Badger
Ivor Badger
  • 846 posts
Posted 30 December 2011 - 12:38 AM
998 engine trying to push 4 x 7" wide wheels which are probably so far offset that the inner side of the rim is outside the brake disc. at least the discs will be cool if it ever goes fast enough to need to use the brakes. Of course, I suspect it will handle that badly, that you will need to slow down quite a lot for every corner.
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 30 December 2011 - 04:46 AM
Partially true, it's because they are steel which means the metal is not so thick on the flange, also the shape of the wheel. But to fit 10x6" wellers, the calipers still need to be modified by relocating the mounting holes and some careful machining on the outside..
IMO, if you want 10" wheels, use 7.5 or 7.9" disks and appropriate calipers.
There is only one set of wheels which will fit an un-modified 8.4" disk brake system, and that's those with the huge offset which mount the wheel's inner edge outside of the caliper. You will require sportpack width arches to cover these wheels.
#8 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 30 December 2011 - 08:10 AM
yes don't tell your insurance company , don't crash and don't let VOSA do a road side inspection
#9 Ivor Badger
Ivor Badger
  • 846 posts
Posted 30 December 2011 - 12:14 PM
and carry 2 spares for the side wall damaged punctures.
#10 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 30 December 2011 - 02:00 PM
I'm pretty sure that the ones pictured are the golf cart ones
#11 mt2man
mt2man
  • 149 posts
Posted 31 December 2011 - 02:28 PM
I havent got a 998 in my car? haha and fair enough if 10's wont clear my brakes then i will go upto 12's or maybe 13's!
I was speaking to my local tyre fitters and they said it is a grey area and it isnt illegal to have stretched tyres fitted and they will fit them.
The ones showed in the picture are the golf cart wheels but they look identicle to the wheels in question, it was just to get an idea of what they looked like! They are made of the same alloy and a mini is well within the weight limit they are designed for, some of the golf carts in america are road legal and capable of speeds most standard minis couldnt acheive!
#12 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 31 December 2011 - 04:25 PM
now phone your insurance company and tell them you a fitting tyres to rims wider than what the tyre makes recomend
let us know if they are happy
Edited by Bungle, 31 December 2011 - 04:26 PM.
#13 mini.cooper998
mini.cooper998
  • 685 posts
  • Local Club: looking
Posted 01 January 2012 - 05:01 PM
look on force racings website, they do wheels that look similar to the potenza's and are very strong. Carl might also be able to tel you if you can fit them over 4pots
#14 MiniMenzies
MiniMenzies
  • 190 posts
Posted 02 January 2012 - 03:02 AM
the wheels in the photos are not real Gianni Potenza's they are from an american company i think its on a thread on the turbo mini forum. I also have a feeling that he is on here too ??
http://www.turbomini...tid=385799&fr=0
:) Nic
#15 Driezzie
Driezzie
  • 662 posts
Posted 02 January 2012 - 09:38 PM
Yes I posted something about it already but that's not his question, maybe the name of the topic is confusing. I'm also 99% convinced they are the same mt2man ;). Made in China by the way.
http://www.theminifo...heaper-version/
Edited by Driezzie, 02 January 2012 - 09:39 PM.
