Snapped Rockers
Posted 31 December 2011 - 11:15 AM
after re fitting the standard rockers to my new engine i took the car up the m42 last night.
after about 6 miles there was a knocking noise coming from the engine so i called breakdown rescue and got pulled home.
i've taken the rocker cover off and found the problem, a snapped rocker. it's broken clean off the shaft at the pushrod end.
is this uncommon or is there a good reason for this happening before i put another set on?
engine spec
CAM4180 head skimmed too much for class1 auto grass! with inlet and exhaust opened up to match gasket & manifolds, chamber heart tips rounded a little
standard forged rockers
genuine cooper 3 into 1 exhaust manifold
kent 276 cam
good gear box from a low mileage 1275 allegro engine
3.1 diff
Posted 31 December 2011 - 12:11 PM
I have a full rocker set for sale if your interested for £26.00 with postage if your interested?
Posted 31 December 2011 - 12:37 PM
Posted 31 December 2011 - 12:38 PM
Posted 31 December 2011 - 02:23 PM
Posted 31 December 2011 - 04:26 PM
i put another set of rockers on in case there was a fracture or weakness in the rocker.
it started up and idled fine i drove it 2 miles if that and bang snapped in exactly the same place.
Posted 31 December 2011 - 05:04 PM
The problem could be a bent valve stem. If it jams in the guide then it could cause the problem you describe. but god knows how you got it runing again with just new rockers..
Edited by AndyMiniMad., 31 December 2011 - 05:07 PM.
Posted 31 December 2011 - 05:06 PM
As for hitting the piston, well you could take the head off, which is not a very big job, put some plasticine on the top of each piston, put the head back, with the old gasket for now, check that the clearances are correct and adjust if necessary, and turn it over a couple of times. The plasticine will tell you how much clearance you have.
Posted 31 December 2011 - 05:17 PM
i presume this mixture of cam and head has been done before? i'm not sure how much has been skimmed off the head and whether simply putting an un skimmed cam4810 will cure the problem.
i can't afford to spend more money on a new head, as suggested in a previous topic, such as a 295 or 202 etc and there's only so many times i'm prepared to put my head under the bonnet doing the same things over and over again just to have the rockers snap again.
Posted 31 December 2011 - 05:22 PM
Posted 31 December 2011 - 05:25 PM
Posted 31 December 2011 - 05:51 PM
Posted 31 December 2011 - 05:56 PM
i then used 2 sets of the later a+ standard rockers which both snapped at cylinder 3 exhaust valve
Posted 31 December 2011 - 06:00 PM
Posted 31 December 2011 - 06:31 PM
so in theory another un skimmed head should solve it?
