gear grind 3rd to 2nd
14 replies to this topic
#1 Monkeh
Monkeh
  • 159 posts
Posted 11 February 2006 - 10:29 PM
Whenever i change from 3rd to 2nd above a certain speed (about 25mph) it always grinds. does anyone else experience anything similar, or have i got a worn out gear/synchro?
#2 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 11 February 2006 - 10:30 PM
think it is the synchro but guessworks is your man.
look in his sig for info on gearboxes
#3 Jammy
Jammy
  • 25,397 posts
Posted 11 February 2006 - 10:31 PM
Sounds like a worn synchro.
Moved to tech section.
#4 Lt-SilverDragon
Lt-SilverDragon
  • 724 posts
Posted 11 February 2006 - 10:32 PM
Yeah mine does the same I just slow it down more now.
#5 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
  • Local Club: Shatrats.com
Posted 11 February 2006 - 10:38 PM
I used to have the same prob...
Changed the master cyl and prob solved.
#6 crocstarr
crocstarr
  • 1,500 posts
Posted 11 February 2006 - 10:59 PM
i heard it was the synchro aswell. couple of hundred quid. had problem when test driving one the once, so i didnt buy it.
now ive changed mine to quickshift and if i lift to high for reverse the whole gearstick wobbles round. great. lol
#7 binge
binge
  • 2,508 posts
Posted 11 February 2006 - 11:21 PM
Ive had 4 manual Minis. (well, 3, but one has had 2 engines)
And all 4 engines Grind from 3rd to second when I was giving it some.
I usually Just double clutch it, it sounds racey too. :D
For those who dont know how to double the clutch, Then its simple enough.
Clutch down,
Into Neutral
Clutch up,
Give it a rev
Clutch down
Into 2nd
Clutch up
away you go
Sounds complicated, Ive got it down to a Tee now, Been driving like that for a bout 6 months. I can now also heel / toe it too, So whilst im engine brakeing, I can also Hold the brake pedal with my heel, and give the throttle some revs to allow me to double Clutch it to down change to 2nd.
people must think Ive got like 3 legs when they see my brake lights on AND hear my throttle go Vrooom! :D
But yea, I wouldnt worry too much about the grinding to be honnest. Learn how to double clutch and you will have NO problems what so ever. :(
#8 Lt-SilverDragon
Lt-SilverDragon
  • 724 posts
Posted 12 February 2006 - 12:05 AM
Double declutch :D
Don't even need to heel and toe in a mini you can put your foot on the brake and accelerator at the same time anyway :D
#9 minimole
minimole
  • 781 posts
Posted 12 February 2006 - 12:35 AM
in my cav i can change gears without using the clutch at all :lol
#10 chrisls
chrisls
  • 34 posts
Posted 12 February 2006 - 02:37 AM
Thats impressive getting the speeds matched dead on? I must lear to double clutch for those 3rd to 2nd changes especialy.
#11 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 12 February 2006 - 06:03 AM
You can change gear in any car without depressing the clutch, as long as you can match engine and road speed.... but... you will wear your gearbox, as more often than not, if you are pressing on you will miss and grind the gears. It is the dog teeth on the gears you are grinding and not anything else, so rebuilds would immediately become more expensive as a rebuilder would not accept your box as an exchange.
Best thing to do is get another gearbox, off ebay or such like, and then get it rebuilt, if you can't have you car off the road for any period of time.
#12 binge
binge
  • 2,508 posts
Posted 12 February 2006 - 09:02 AM
Just for the record, IM not Clutchles changing!
Just incase thats what your saying. I Can Do it, Ive tried, and if you can get a good speed Lineup, then clutchless changes are ok, But I dont really feel comfortable doing them.
Double clutching is Different. Call me "mr State the obvious" but It sounds like some of you think Im clutchless changing.
#13 Monkeh
Monkeh
  • 159 posts
Posted 12 February 2006 - 02:19 PM
ill give the "double clutch" a go and see if it works
#14 minimole
minimole
  • 781 posts
Posted 12 February 2006 - 05:09 PM
in my defence the clutch is very worn and the gearboxis on it's way out which is why i tried it to begin with as the engine gearbox is coming out soon anyway :D
#15 Lt-SilverDragon
Lt-SilverDragon
  • 724 posts
Posted 12 February 2006 - 05:14 PM
So the grinding is a bad thing I just thought I was shifting into 2nd at too high a speed as my speedo doesn't work.
