Alloy Door Skins
Posted 02 January 2012 - 12:15 PM
what are alloy door skins like? anything bad about them or are they just the same as having a steel one?
cheers
steve
Posted 02 January 2012 - 04:33 PM
I used to have a Rover P4 with complete alloy doors. They were great, light for their size, and resisted corrosion quite well. They were said to dent easily, but I never found that to happen. But an alloy skin on a steel frame is another matter altogether. There is a real risk of electrolytic corrosion at the joint between the two metals.
I am assuming that you want the car to have a long life. You should paint the steelwork before fitting the new skin, with the usual etch primer, and as many coats of normal primer as you want, also do the same with the inside of the alloy skin. I would then use a generous amount of adhesive, the stuff used for bonding panels on cars designed to be assembled that way, on the edge of the frame, and then place the skin in position. Once the bonding has set, put more on the frame edge, before turning over the edge of the skin. That will be messy, you have to do it while the adhesive is wet!
That way the interface between metals is completely filled with adhesive, with some layers of paint too. But I would still spray lots of waxoyl around the inside of the seam.
One problem is that there are normally a few welds near the top of the skin, and you can't do that, because of the adhesive, and also rather exotic techniques are required to weld alloy to steel. I think you could live without these welds as an adhesive bonded skin will be more secure than one which is mostly relying on just being crimped.
Oh, and normally I would not like bonded panels, definitely not anywhere in the monocoque, but doorskins are not a part of the monocoque and don't normally carry dynamic loads.
Posted 02 January 2012 - 04:58 PM
Posted 02 January 2012 - 05:06 PM
Posted 02 January 2012 - 05:29 PM
Posted 02 January 2012 - 05:31 PM
Posted 02 January 2012 - 08:11 PM
I decided to get my old frames repaired and ally skinned by minidoor. I wish i had done this at the start! They are loads stiffer - mainly because of the metal hoop still being kept, obviously not as stiff as the full steel door but after the F/G doors its nothing im going to complain about.
They are not loads lighter but you can definitely feel the difference - with perspex and some of the frame cut out it does save a few kilos
Downside - you have to find the parking space miles away from the shops to avoid parking next to another car - they dent very easily!! Dont close the door still holding onto the handle as it can dent in the handle! But its nothing i cant live with - i treat my car like a newborn anyways!
In my opinion, its not a massive weight saving if you are keeping the winder mechanism etc by going ally skin, but if you are after weight saving i would highly recommend them over Fibreglass, as a compromise.
Hope this helps
Andy
Posted 02 January 2012 - 09:49 PM
carbon ones won't be any diff unless they were made from pre preg carbon and i can't afford that even if i made them myself, couldn't afford the material.
how much lighter than a steel skin is an alloy one? or is the weight saving mostly in gutting them anyway.
Posted 03 January 2012 - 03:49 PM
http://home.freeuk.n...acing/doors.htm
Posted 03 January 2012 - 06:19 PM
Like ive said before, im happy with the ally skinned doors i have, but mine is not a daily driver - if it was i would get the steel.
Andy
Posted 03 January 2012 - 09:02 PM
trust me the hoop will be no diff than the fibreglass ones, even if they were pre preg it wouldn't be much different
i'm a composite laminator by trade, we make components for all the top f1 teams
i have access to a plenty big enough autoclave, but making a mould and then the doors will be way too expensive,
think gutted steel ones is the way forwards
Posted 04 January 2012 - 04:57 PM
If i had autoclaves big enough to fit car parts in i would go hungry, as i would take my salary in carbon parts!!
Andy
Posted 04 January 2012 - 11:23 PM
