Shopping Time For Shiny 1275 Engine Bits
14 replies to this topic
#1 jameslearwood
jameslearwood
  • 525 posts
  • Local Club: ALL ALONE
Posted 05 January 2012 - 04:28 PM
As the title says about to start getting parts for my Mini 1275 engine from a 1993 rio currently doing a rebuild http://www.theminifo...-d/page__st__45
engine currently at engineers getting polished up and new bearings.
So time to start getting new parts in the only thing is not 100% certain on which bits to replace standard and which to upgrade.
  • Oil pump i have no idea which to get?
  • water pump is this worth replacing?
  • timing chain isnt duplex what implications does this change have?
  • new clutch thrust pad i can't seem to see them on mini spares without buying a whole new clutch.
  • Flywheel contemplating changing to ultralight so if i have verto the starter is engaged is this correct?
I sort of have an idea just not 100% so any help on the above would be great i've excluded simpler stuff such as gasket kits and cam followers
cheers
#2 nickcooper
nickcooper
  • 132 posts
Posted 05 January 2012 - 04:53 PM
Oil pump definatly, which one you need is defined by what the drive is off the camshaft I.e slot drive.
Water pumps always worth replacing,
If you give minispares a ring they can normally supply parts like that.
Not sure about the verto thing, mines verto and I think I have an engages type not for sure tho
Good luck, I enjoyed doing my rebuid
#3 jameslearwood
jameslearwood
  • 525 posts
Posted 05 January 2012 - 05:37 PM
Right okay thats the oil pump sorted
http://www.minispare...ty=pb&pid=34203
http://www.minispare...pid=32665=
and water pump
http://www.minispare...ty=pb&pid=32778
correction i think i do have a duplex timing chain it does look the same so i dont need to replace that bit? just the tensioner.
getting rid of the bypass in the thermostat why do it?
anyone have any ideas on what these pistons are 21962 p4 x11 id5
#4 jameslearwood
jameslearwood
  • 525 posts
Posted 05 January 2012 - 05:39 PM
cheers nick think i'll enjoy it more when i begin assembly :D
#5 nickcooper
nickcooper
  • 132 posts
Posted 05 January 2012 - 06:27 PM
Depends how far you want to go with your rebuild and also your money situation.
Personally I would change the chain regardless, also the sprockets, it all depends on how much running the engine has had with parts like that on. Depends on your money situation and how much you want to tune your engine, a verneir duplex allows for more acurate adjustment. With the solid ones to change timing this is done with a shifted key.
Its up to you really, you need to think ahead.... How long parts will have left in them, its worth doing stuff now so you dont have to do it later.....its also down to your budget.
#6 nickcooper
nickcooper
  • 132 posts
Posted 05 January 2012 - 06:37 PM
When you say your block is being polished and new bearings, do you mean a rebore?
#7 jameslearwood
jameslearwood
  • 525 posts
Posted 05 January 2012 - 06:41 PM
nope not reboring just polishing up getting rid of slight ridges not looking into major changes just slight changes at the minute.
I've heard the vernier duplex is the one to get might have a look into it cheers what are the sprockets?
#8 nickcooper
nickcooper
  • 132 posts
Posted 05 January 2012 - 06:49 PM
Hey must be very slight, the bore has to be perfect and honed properly, the bores have to match each piston exactly, when I had mine rebored I had them match the bores to the pistons, even though they were brand new they are still Very slightly different.
The sprokets are the 2 "gears" the chain fits onto, its the sprocket thats the vernier adjustable bit, the chains just a duplex chain.
Edited by nickcooper, 05 January 2012 - 06:52 PM.
#9 jameslearwood
jameslearwood
  • 525 posts
Posted 05 January 2012 - 06:58 PM
righto thought so cheers.
yeah he has me piston so is getting the bores to match just found some pistons that are in much better condition and slightly better courtesy of andyminimad so going to ring the engineer in the morning and see what he thinks
cheers for your help
any help on the clutch and flywheel please
#10 jameslearwood
jameslearwood
  • 525 posts
Posted 05 January 2012 - 09:32 PM
these are the two chains i found
http://www.minispare...pid=36528=
http://www.minispare...pid=38067=
The latter i think is the one i want the adjustable one is £80 and out of stock, do i need a tensioner with these?
#11 jameslearwood
jameslearwood
  • 525 posts
Posted 05 January 2012 - 09:41 PM
http://www.minispare...ty=pb&pid=34526
Radiator im looking at what do you people think this appears to be the better one on a budget. mine is leaking and battered to hell so want to replace like the idea of unscrewing the switch to drain
#12 jameslearwood
jameslearwood
  • 525 posts
Posted 05 January 2012 - 09:53 PM
is this the clutch plate i need http://www.minispare...=0&tc=1#submenu
is this the right flywheel http://www.minispare...ty=pb&pid=37371
cant get my head around it if i improve the flywheel do i have to change the clutch pressure plate?
#13 freshairmini
freshairmini
  • 1,718 posts
Posted 05 January 2012 - 11:24 PM
Don't need a tensioner with duplex kit.
(null)
#14 jameslearwood
jameslearwood
  • 525 posts
Posted 06 January 2012 - 10:41 AM
cheers fresh
#15 jameslearwood
jameslearwood
  • 525 posts
Posted 06 January 2012 - 05:24 PM
well just spent £250 at minispares not sure how that makes me feel, probably happy when it arrives :(
So that is a new oil and water pump, new radiator and complete gasket set, some bits and bobs plus a new clutch breather and my cam followers.
still leaves timing chain for adjustable duplex £68 and lightened flywheel and clutch plate will wait for the engineers bill before deciding
