Crunching Gears, Only When Cold.
Posted 05 January 2012 - 10:42 PM
But what I can't understand is how after about 2 - 5 minutes of driving depending on how cold it is outside the crunching will stop however fast I put it into gear.
Could this be just the cold or the fact that the syncros work better when warm? can't see it myself.
Must just be that my oil is over a year old and the cold weather? possibly 10w40 being wrong too.
Just wondered on what people thought about this?
Posted 05 January 2012 - 11:03 PM
Posted 05 January 2012 - 11:38 PM
Posted 05 January 2012 - 11:39 PM
Posted 05 January 2012 - 11:51 PM
Posted 06 January 2012 - 12:06 AM
Posted 06 January 2012 - 12:07 AM
My clutch makes a bit of a squeeking noise too when pressed, my guess it is the pedal though?
Thanks for your help.
Edited by thebullet, 06 January 2012 - 12:08 AM.
Posted 06 January 2012 - 12:47 AM
just be gentle.... :)
Posted 06 January 2012 - 10:20 AM
Edited by thebullet, 06 January 2012 - 10:20 AM.
Posted 06 January 2012 - 10:57 AM
Posted 06 January 2012 - 01:23 PM
The clevis pins on the pedal, the master cylinder pushrod, the throw-out arm, the ball on the throw out arm... all that play adds up. If your clutch is marginal, replacing those parts that pivot can really help.
If you have a pre-verto clutch, make sure the clutch adjustments for the "big stop" and the throw-out arm are correct. In fact, the throw-out stop position can be set a bit tighter than factory spec if necessary to "raise the pedal" a bit.
Posted 06 January 2012 - 01:41 PM
All gearboxes even on modern cars can be a bit notchy when cold as the oil is much thicker and thins and as it warms up. I always had the same problem with my Impreza, changed the oil to a slightly thinner grade and it cured the problem. I also have this on my golf tdi when very cold...
Posted 06 January 2012 - 03:18 PM
But isn't that thicker?
Will look at what is suggested, but it after a few gear changes the crunching stops in higher revs, I don't tend to rev it when it is cold anyway, always short shift so I don't notice it as much.
Nornally when going into second I notice it the most.
Posted 06 January 2012 - 05:17 PM
Posted 07 January 2012 - 10:26 AM
