1995
Spi
I went on holiday and the mini has been standing for 3 weeks ( on a hill on the handbrake and left in 1st), when I came back obviously it needed a battery charge but I also cannot depress the clutch pedal.
does anyone think the fact that I had left it in gear could have caused this? or the fact it been sitting on a slope?
What would be your thoughts?
(over the weekend I am going to check the clutch fluid, havent had chance yet as havent had the light with the dark nights)
Clutch Pedal Wont Depress, Like A Lump Of Concrete!
frenchie851
, Jan 06 2012 04:06 PM
3 replies to this topic
Posted 06 January 2012 - 04:06 PM
Posted 06 January 2012 - 04:10 PM
Easy one and very common!!
The clutch arm has siezed at its pivot point, give it a spray with some wd40. If you've got a pig pry bar.crowbar use that to work the lever loose.
(just in case you don't know the lever I mean is the arm that the slave cylinder pushes on)
Posted 06 January 2012 - 05:16 PM
Either that or the slave cylinder is rusted up ans seized!!
Posted 20 January 2012 - 05:32 PM
Chock the wheels and take out of gear, start the car and allow the engine to fully warm up, the thermal transfer through the metal should help un-seize with lots of wd40 or other penetrating fluid
