Flywheel Is Loose
7 replies to this topic
#1 Jack rabbit
Jack rabbit
  • 45 posts
Posted 08 January 2012 - 10:12 AM
Ok so I have got to the flywheel today and it is loose. with engine still i can turn the clutch flywheel assembly about quarter of a turn in each direction? I think this isn't going to be a case of tightening up but I'm not sure any ideas ?
#2 oltonlad
oltonlad
  • 2,401 posts
Posted 08 January 2012 - 10:18 AM
the flywheel to crank key is most likely damaged, they are about £9 new. (i have provided pics of the verto and non verto crank keys as they are different.
make sure that the end of the crank hasnt been damaged.
here is a pic of what you need.
Edited by oltonlad, 08 January 2012 - 10:21 AM.
#3 Jack rabbit
Jack rabbit
  • 45 posts
Posted 08 January 2012 - 10:20 AM
Are yes I didn't think about that I'm going to remove the flywheel later hoping the crank is ok
#4 oltonlad
oltonlad
  • 2,401 posts
Posted 08 January 2012 - 10:23 AM
at least the flywheel will come off easily so that will be a bonus....... :proud:
#5 Jack rabbit
Jack rabbit
  • 45 posts
Posted 08 January 2012 - 10:49 AM
Lol maybe an enjoyable job that will be a first I may have some knuckles left after
#6 tiger99
tiger99
  • 8,584 posts
Posted 08 January 2012 - 04:46 PM
Be sure to lap the flywheel to the crankshaft taper if it has been loose. The fit of the taper actually carries all the dynamic load once it is correctly torqued up.
#7 bmcecosse
bmcecosse
  • 9,699 posts
Posted 08 January 2012 - 04:50 PM
If the flywheel has come loose in service - there is something seriously wrong.... It won't just be a case of a new keywasher - in reality that washer does nothing except for initial installation - the taper fit carries all the power. If it is loose - the tapers will be ruined. Are you sure that's the problem - and not a broken crank?
#8 Jack rabbit
Jack rabbit
  • 45 posts
Posted 08 January 2012 - 06:53 PM
Yes with the clutch in it starts up fine I think the clutch is pushing the flywheel into place I think it's going to be an engine out job I reckon the crank will be dead I will have a good look in the week
