G3, Does It Fade Paint?
10 replies to this topic
#1 purple_fly06
purple_fly06
  • 594 posts
  • Local Club: The Mini Foresters
Posted 09 January 2012 - 10:20 AM
I have recently had my mini resprayed, but it needs compounding. I was going to compound it with G3 but i was told that it contains ammonia which will fade the paint. will it be better if i used G6 instead or will this fade the paint as well? I dont want to use a rough compounding paste either only a light one as all the paint needs is a good buffing up.
I will be using a brushing mop and i know that i will need to keep spraying with water and not let the compound go dry otherwise it will burn.
Josh
#2 samsfern
samsfern
  • 5,243 posts
Posted 09 January 2012 - 10:29 AM
I'd try the g6 first. G3 could be a bit harsh. Also once you've finished make sure you wash all the compound off and polish it with some good quality polish then give it a coat of good quality wax to seal it.
#3 purple_fly06
purple_fly06
  • 594 posts
Posted 09 January 2012 - 11:03 AM
ok, thanks for that, so G6 it first, then some high resin polish and and good wash and wax :lol:
Josh
#4 Sam Walters
Sam Walters
  • 2,765 posts
Posted 09 January 2012 - 01:20 PM
Do you have the g3 or g5 yet? Get 3m fast cut if you dont.
#5 purple_fly06
purple_fly06
  • 594 posts
Posted 09 January 2012 - 02:59 PM
no i dont yet, is 3M Fast Cut better for what i need to do?
#6 minimartin1
minimartin1
  • 276 posts
Posted 09 January 2012 - 05:36 PM
3G is best on market. After a car has come out the spray booth we flat it back with 2000 grit wet n dry and buff it up with 3G.
#7 redhot-mini
redhot-mini
  • Just Joined
  • 537 posts
  • Local Club: North Devon Mini Register
Posted 09 January 2012 - 06:06 PM
^^ yer i was going 2 say g3 is good stuff ive used it on every car ive sprayed and come up looking so nice
Edited by redhot-mini, 09 January 2012 - 06:09 PM.
#8 smyrk
smyrk
  • 71 posts
Posted 10 January 2012 - 04:09 PM
id go for 3m fast cut+, i do alot paint corrections and wet sand paint when its been left with alot of orange peel and the 3m is what i use time and time again
#9 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,091 posts
  • Name: Neil
Posted 12 January 2012 - 09:03 PM
Try Scholl Concepts S17+. I used G3 on Erm and at first thought it was ok but then got recommended the Scholl product and its much much better.
This is the finish i have got on Erm after flatting back with 2000 wet and dry and then using S17.
Still got to redo the doors and the bonnet after the paint shop used G3 and you do notice the difference.
#10 Sam Walters
Sam Walters
  • 2,765 posts
Posted 13 January 2012 - 03:55 PM
I can only presume swirl marks and the like?
That car is certainly something and is a credit to you and your lad!
#11 sonikk4
sonikk4
  • 16,091 posts
  • Name: Neil
Posted 13 January 2012 - 08:06 PM
I found with the G3 it dulled the paintwork slightly but when i used the S17+ the shine was there straight away and only needed a quick buff over with Perfect III and that was it. No swirl marks at all.
The paintshop had used G3 on some of the panels when they put plastic sheeting over the panel and left marks DOH!!! however they were removed easily with the G3 but i now have to go over them with the S17+ to bring up the shine. But before that they will be colour sanded to knock off any high spots and some very minor orange peel.
