Mpi - Idle And 2000-2500Rpm, Intermitant Loss Of Power.
15 replies to this topic
#1 nev_payne
nev_payne
  • 2,249 posts
Posted 09 January 2012 - 09:20 PM
While SirD hasn't even hit 200 miles as far as breaking in is concerned, I've become increasingly aware of a lack of engine power in the above rpm range. While the idler gear is rattling and this will be replaced in the Spring, I'm sure is related to electrimagicals/sensors. To keep things clean:
- Idle is very throaty, needle sitting at 900rpm but sounds like there's a lumpy cam especially when cold, persists when the engine is warm. Feel like I have to keep constant attention on the revs in case they drop. With the clutch pedal depressed, while the idler gear does shut up, the revs continue to sound like there's a race cam in there (the cam wasn't replaced, original as far as I'm aware).
- Especially notable in 2nd and 4th gear (driving through town, cruising on the main road at 40-45MPH respectfully).
- In the RPM range it feels like the battery (brand new, pulling 14v from alternator) is running flat or possibly a lack of fuel.
- Above the range is perfect and more than happy to accelerate on with no hesitation.
Suggestions welcome and thanks in advance, more than happy to post a video that would help :)
Nev_Payne
Edited by nev_payne, 09 January 2012 - 09:22 PM.
#2 nev_payne
nev_payne
  • 2,249 posts
Posted 12 January 2012 - 08:05 PM
Anyone got an idea? :unsure:
#3 nev_payne
nev_payne
  • 2,249 posts
Posted 15 January 2012 - 07:28 PM
Anyone at all? Passed onto Turbo Minis to seek more help.
#4 nev_payne
nev_payne
  • 2,249 posts
Posted 18 January 2012 - 09:03 AM
It's awfully lonely in here...
#5 bcjames
bcjames
  • 2,728 posts
Posted 18 January 2012 - 09:12 AM
*tumbleweed*
If you think it's related to sensors, are you able to have it plugged in and checked? That clever Mr Yardy did mine. It flagged a couple of issues with sensors, one of which was sorted with cleaning the sensor, and the other needs replacing and should be arriving today.
There's quite a few threads on here regarding badly running mpis, I just followed a few of them to check things before I could get it plugged in, even if the symptoms weren't immediately related to my problem. I wouldn't fancy replacing sensors blind, could get expensive!
#6 tmsmini
tmsmini
  • 734 posts
  • Local Club: MOASF
Posted 19 January 2012 - 08:35 PM
When replacing items were any adjustments attempted to the throttle body or has anyone ever tried to adjust the idle by adjusting the throttle body? This can cause problems as it requires a service reset.
Terry
#7 nev_payne
nev_payne
  • 2,249 posts
Posted 20 January 2012 - 09:24 AM
Very good points. Need to find myself a ye olde Rover garage.
#8 nev_payne
nev_payne
  • 2,249 posts
Posted 31 January 2012 - 11:23 AM
Waiting for the weather to not be freezing cold/wet and pass the daily salt dumps on the road. Video just for some clarity:
Edited by nev_payne, 31 January 2012 - 11:32 AM.
#9 liam_italian
liam_italian
  • 1,417 posts
Posted 31 January 2012 - 05:42 PM
vacuum leak!
#10 nev_payne
nev_payne
  • 2,249 posts
Posted 01 February 2012 - 12:11 AM
Removed and cleaned the IACV - sorry Liam I only read your message after I got back in from the garage >_< which part of the valve did you break - the black spring loaded sleeve?
The torx screws wern't exactly tight upon removing, but the breather pipe was fitted tightly. The valve was completely caked in carbon:
A clean up with brake cleaner and a 15 minute wrestle with the wiring loom later..
Much nicer, though in true Mini sense, Sir D is now aware that things are being fixed - so the fan belt is the next thing. :withstupid:
Edited by nev_payne, 01 February 2012 - 12:14 AM.
#11 Dylan8660
Dylan8660
  • 206 posts
Posted 06 February 2012 - 09:22 PM
Why stop at the iacv? what about the map and air flow, and not forgetting the actual tb, they'll be crudded as well.
#12 nev_payne
nev_payne
  • 2,249 posts
Posted 07 February 2012 - 09:05 AM
Because the majority of that was cleaned and checked over prior to the restoration. What I need now is a sensor check.
#13 R1minimagic
R1minimagic
  • 4,660 posts
Posted 07 February 2012 - 09:48 AM
Hi, was the crank sensor purchased for this car? Also, why did you buy the stalks? Got another Mini?
by the way - posted that small bracket yesterday
Dale
#14 nev_payne
nev_payne
  • 2,249 posts
Posted 07 February 2012 - 12:27 PM
Hey chap,
Yeah it's all for spares back-stock, that way it's a quick change out when required.
#15 nev_payne
nev_payne
  • 2,249 posts
Posted 08 April 2012 - 11:08 PM
Okay then.
- ECU was cleared 2 weeks ago and did 300 miles following
- New clutch 300 miles ago and no oil leaks since
- All breather hoses are clear
- New coolant and oil in the last 0 miles
- IACV was cleaned the last time round along with the MAP and all the spark plugs
This was the idle today:
The only thing left that's not been checks due to it's location is the idler gear. Could anyone verify for me that this is pretty much the route cause for this intermittent idle?
Edited by nev_payne, 08 April 2012 - 11:09 PM.
