Piper Cross Or K&n?
15 replies to this topic
#1 tomtaylor1994
tomtaylor1994
  • 338 posts
  • Local Club: DCMOC
Posted 09 January 2012 - 10:26 PM
Hi all,
I have a '98 Rover MPI 1275 and would like to stick a new air filter on it...
Does anyone have experience with either the K&N or piper cross Multiple point injection filters and which one would you recommend?
Thanks in advance :)
#2 Mini_Magic
Mini_Magic
  • 5,747 posts
Posted 09 January 2012 - 10:41 PM
They'll probably be almost exactly the same, except for the way they look.
You will get no noticeable difference in performance, but they may sound a little different depending on the design.
The K&N on a MPi does give it a very nice sound on acceleration and overrun.
#3 nev_payne
nev_payne
  • 2,249 posts
Posted 09 January 2012 - 10:45 PM
I'd recommend the K+N as an insert to the original filter housing instead of the cone n' pipes. After a whle the pipes just cheese you off when you want to do anything in the engine bay.
#4 tomtaylor1994
tomtaylor1994
  • 338 posts
  • Local Club: DCMOC
Posted 09 January 2012 - 10:47 PM
No difference in performance? :o I thought that was what air filters are all about :/
#5 tomtaylor1994
tomtaylor1994
  • 338 posts
  • Local Club: DCMOC
Posted 09 January 2012 - 10:48 PM
Hmmm, so they're noisy? :P
#6 nev_payne
nev_payne
  • 2,249 posts
Posted 09 January 2012 - 10:51 PM
Definitely noisier than having the air filter housing. I'd take an easy to maintain engine bay over noise - get enough coming out the exhaust nowadays.
#7 tomtaylor1994
tomtaylor1994
  • 338 posts
  • Local Club: DCMOC
Posted 09 January 2012 - 10:53 PM
Thanks for the advice :) and is it true I won't see an improvement in performance?
#8 Mini_Magic
Mini_Magic
  • 5,747 posts
Posted 09 January 2012 - 10:58 PM
You don't have to have those extra pipes though, they do little to get cold air to the filter.
I had a cone filter, same as the above but without the pipes, and had no problems.
#9 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 09 January 2012 - 11:01 PM
Pretty much, yup.
#10 JakeJakeJake
JakeJakeJake
  • 836 posts
Posted 09 January 2012 - 11:02 PM
I believe he means between the two. Will be better performance than standard
#11 Mini_Magic
Mini_Magic
  • 5,747 posts
Posted 09 January 2012 - 11:17 PM
I actually meant between a "performance" air filter and a standard one. The power increase is very little really.
You'll only really notice a slight power increase if you put the car on a rolling road.
Still worth getting one thought, just for the sound it makes!
#12 JakeJakeJake
JakeJakeJake
  • 836 posts
Posted 10 January 2012 - 12:32 AM
Can't really rolling road a MPI ;)
#13 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 10 January 2012 - 01:10 AM
it's got wheels and an engine so you can ;)
#14 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 10 January 2012 - 11:03 AM
Yes, but you won't be able to change the fuelling at all as the ECU cannot be altered.
#15 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 10 January 2012 - 04:53 PM
no one was talking about fuelling, only power gains with a different filter.
