Thanks Cooperman, I thought that would be the case especially as the machining is being done in the UK and the real build overseas. Having thought about it some more, a trail build is the only way to go.
Notay - I'll scan my back of a fag packet calculations with drawings on here later. I'll soon find out if it's right :) but basically it all works on the volume of a cylinder being pi x r² x h. Pi is of course 3.1416, r half of the 73.5mm bore and h any of the below :
1) gasket "height" ie thickness
2) The cylinder stroke = 81.28mm
3) The deck height.
Add the head volume, the gasket volume, the piston dish, the cylinder volume at BDC to a total and divide this by the sum of the head volume, the gasket volume, the piston dish and the cylinder volume at TDC (given by the deck height) to give the ratio. A zero deck height where the top of the piston is flush with the top of the block at TDC is obviously 0 cm³. Be careful to convert the millimeters to cm if you want to do it all in cm³. Ie a deck height of 0.5mm = 0.05cm and r is 3.675cm. Obvious I know but it's easy to make a mistake.....
There was an excel spreadsheet on the net where you filled in the boxes and it gave you the answer but its disappeared.
Edited by govig, 10 January 2012 - 05:57 PM.
