List Of Possible Engines?
14 replies to this topic
#1 Jakeclubby
Jakeclubby
    Previously known as Jakemayfair
  • 1,669 posts
Posted 11 January 2012 - 10:46 PM
Hi
Basically im looking soon to upgrade the beast a bit.
im planning on getting a bigger engine (i currently have a 998 completely standard mayfair)
im looking for some help, i was wondering if you guys could list the engines i could convert to and the cost/price of it. also im only interested in the engines i dont have to modify the sub frame or much really.
im aware of the 1.4k vauxhall and micra but dont really know anything about them.
thanks
#2 coopdog
coopdog
  • 4,506 posts
Posted 11 January 2012 - 10:47 PM
thought about turbo?
#3 Jakeclubby
Jakeclubby
  • 1,669 posts
Posted 11 January 2012 - 10:50 PM
go on ;)
#4 coopdog
coopdog
  • 4,506 posts
Posted 11 January 2012 - 10:52 PM
go on ;)
well think about it ;)
#5 oliver122
oliver122
  • 1,007 posts
Posted 11 January 2012 - 10:53 PM
998 fast road spec (standard subframe)
1275 standard (standard subframe)
1275 fast road (standard subframe)
998/1275 turbo (standard subframe) ( if you dont wish to cut holes out of the bulkhead , then custom manifold is needed )
then other engine's require subframe mods , or custom subframes to be built
#6 Jakeclubby
Jakeclubby
  • 1,669 posts
turbo in my standard 998?? never heard of that
#7 Jakeclubby
Jakeclubby
  • 1,669 posts
Posted 11 January 2012 - 10:54 PM
how much would these engines be??
#8 A362 TTU
A362 TTU
  • 525 posts
Posted 11 January 2012 - 10:56 PM
Would need work similar to 'fast road' to take the turbo - cant just bolt a turbo on a standard really.
As for your cost question - depends what power you want? 80hp? 100? 150? 200?
And how reliable you want the power to be
Edited by howgudami, 11 January 2012 - 10:57 PM.
#9 oliver122
oliver122
  • 1,007 posts
Posted 11 January 2012 - 10:58 PM
if you have got the skills to build one then its cost of parts really , and can vary , look at some of the build threads on here.
998 turbos are becoming more popular due to the increase cost of 1275 engines . if you do think about the turbo route , have a look on the turbomini's forum and look through some build threads
could change the head on the 998 and then bolt a turbo on , as long as the engine is strong start off with (http://www.turbo-mini.com/62147.html)
#10 Jakeclubby
Jakeclubby
  • 1,669 posts
Posted 11 January 2012 - 11:00 PM
i wouldnt mind going down the route of whacking a turbo to my 998
im not skillfull enough yet though
#11 oliver122
oliver122
  • 1,007 posts
Posted 11 January 2012 - 11:04 PM
that makes it look simple that 20hour turbo , and its expensive really
£350 manifolds
£100 turbo carb and plenum
£125 plus probs for a head
then cost of pipe work , electric fuel pump , e.t.c . im thinking about this option , but my engine needs a full rebuild and a possible overbore , so would need new pistons to
#12 valve bounce
valve bounce
  • 694 posts
Posted 11 January 2012 - 11:05 PM
£ for bhp you cant go wrong with a good mg metro engine, i got one last year for £100 65-70bhp striaght from the word go
#13 Jakeclubby
Jakeclubby
  • 1,669 posts
Posted 11 January 2012 - 11:08 PM
sounds good, ive heard of metro conversions, Significant power increase??
#14 SamMason
SamMason
  • 235 posts
Posted 11 January 2012 - 11:18 PM
This might not be what you're looking for, as I see everyone is advising turbos.
But anyways, Yamaha R1 conversion. Promotive or Lynx (any others, maybe?) make the kit to fit it. It's built into a cradle that fits into a standard subframe. 150+ hp, 6 speed sequential gear box, but the setup is pretty costly - £3500 ish, not including the engine itself..
#15 Jakeclubby
Jakeclubby
  • 1,669 posts
Posted 11 January 2012 - 11:21 PM
sounds soooooooooo nice if only i had the mney
