Transfer Case Gasket Thickness
Posted 12 January 2012 - 11:15 AM
I've been told that the typical size is 0.032 and will compress to 0.030, however the gasket I was supplied by minispares is 0.036 thick.
Am I right in thinking that It's compressed size will be 0.034. Sorry if it seems a stupid question but I want to het this right!
Posted 12 January 2012 - 11:43 AM
Best thing to do is dry-assemble the transfer case and box with the idller, but no engine and measure the end float.
Posted 12 January 2012 - 11:52 AM
Edited by Guess-Works.com, 12 January 2012 - 11:52 AM.
Posted 12 January 2012 - 01:15 PM
As above, but I have one here which I use for dry building and it measures between 0.133 and 0.134 (compressed), this is the one which comes in the AJM804B gearbox gasket set.
Do you mean 0.033 - 0.034?
Posted 12 January 2012 - 11:52 PM
Ording a transfer case gasket on its own would result in a different thickness one all together too...
Different suppliers... different thicknesses..
so, as above, only way to be sue is to dry build it and measure as necessary....
Posted 13 January 2012 - 07:44 AM
Yes, sorry....
Posted 13 January 2012 - 01:12 PM
In fact, you can roughly check the transfer gear float with the engine on the box if you remove the 'red' seal and the primary gear to gain access.
Posted 13 January 2012 - 05:03 PM
