Convering rear openers to fixed
Cookie Monster
, Feb 14 2006 07:37 AM
15 replies to this topic
Posted 14 February 2006 - 07:37 AM
Has anyone done this / how easy is it to convert the rear opening windows to fixed sealed units.
Posted 14 February 2006 - 07:59 AM
Not difficult, but fixed rear windows are a ******* to put in, as unlike the winscreen and rear window there's no fillet strip...
Just remove your rear quarters, and the seal from around the window, then might be easier to fit the fixed rubber seal around the glass first and then fit to car. Either way it's a pain..
ps.. the glass is a different size on fixed windows to opening, so you can't reuse it.
Posted 14 February 2006 - 08:32 AM
I'm after switching the other way, so have windows and rubbers to swap.
Posted 14 February 2006 - 10:28 AM
all you have to do is push the old ones out, unbolt the hinges etc. To get new ones in i found it a piece of cake. You need to put the rubber onto the glass itself first then feed a string round it. have some one pushing frm the outside while you pull the string off the rubber inwards to the car. 2nd hand seals will tear doing this so have new ones. Also smear fairy liquid on the rubber to help it slip in easier
Posted 14 February 2006 - 10:48 AM
Great, cheers guys, will have a look into it. Just need to get some windows now, thinks a visit to the scrappy may be in order.
Posted 14 February 2006 - 10:55 AM
like i said though, get new seals. not expensive and makes it a hell of a lot easier!!!
Posted 14 February 2006 - 11:09 AM
Will do, was talking about the glass at the scrappy
Posted 14 February 2006 - 11:39 AM
DO NOT USE FAIRY LIQUID! It has a high salt content, so any liquid left in the seal will make your window rot out very quickly!
Posted 14 February 2006 - 02:34 PM
Cookie monster, mind If I ask why you are changing to non-openers?
Posted 14 February 2006 - 03:19 PM
There seems to be a common water trap on a mini between the bottom of the window and the window recess and I have seen several cars where this area has started to rust (including my lads), also they don't have the most secure closing/locking system in the world. So changing them for fixed will solve both problems.
Posted 14 February 2006 - 05:22 PM
What is "fairly liquid"?
Posted 14 February 2006 - 05:24 PM
its what mrs dk uses for the washing up (soap)
i have the glass for the back windows you can have if you can pick it up
Posted 14 February 2006 - 11:40 PM
Yeah bungle, I hear flights are cheap to where you are now. And ferrys. Teehee.
Posted 15 February 2006 - 06:17 AM
Cheers for the offer Bungle, but I could prob by new for the cost of the fuel down to the back of beyond.
Posted 15 February 2006 - 01:40 PM
"its what mrs dk uses for the washing up (soap)"
You clearly have my wife confused with someone who spends time in the kitchen. What's it like to have a wife who cooks and cleans?
