Tricks Or Tips To Fit New Silicone Hoses?
Posted 14 January 2012 - 04:45 PM
It's the heater hose connecting to the heater matrix. I know it says use some force which I was doing but what sort of lube should be used?
Cheers.
Posted 14 January 2012 - 04:46 PM
Posted 14 January 2012 - 04:58 PM
Cheers.
Posted 14 January 2012 - 05:41 PM
Posted 15 January 2012 - 05:35 PM
The other end wouldn't connect for love nor money though, I'll give KY a shot when I can get some free time.
Not sure what my next move is if KY doesn't work.
Posted 15 January 2012 - 05:51 PM
Edited by samsfern, 15 January 2012 - 05:52 PM.
Posted 15 January 2012 - 10:21 PM
Just force it on with a bit of lube and a wiggle and it should go on.
I assure you, much force and wiggling (with a few more descriptives) was carried to no avail. The hoses are just so bloody tight.
Wondering if there is a way of softening them up a bit?
Round 3 at some point this week.
Posted 15 January 2012 - 10:24 PM
Posted 15 January 2012 - 10:26 PM
Posted 16 January 2012 - 07:23 AM
Posted 16 January 2012 - 05:59 PM
There are two sizes or heater hose used on Minis, sure it's all the right size?
Bought the hose kit from minispares so seems to be correct. The hose that goes from the heater matrix I believe is 5/8". There is a metal "lug/cylinder" that connected the previous 2 hoses (heater - Y-shaped hose that goes from the bottom of the rad to the heater hose.)
I think the old metal adapter converted 1/2" to 5/8", now if both my hoses are now 5/8" I'm now thinking there must be a different adapter to connect the 2 hoses.
The reason (i think) that the Y-shaped hose will not connect (just below the thermostat) is age related. The pipe output is a bit honking, trying to get something abrasive to the underside which isn't easy.
Posted 16 January 2012 - 10:43 PM
http://www.minispare...=0&tc=1#submenu
I appear to have struck a bit of a problem here as both hoses (that i am attempting to attach) are the same diameter/circumference and all the adaptors seem to be of the step up/down variety??
Please tell me this is not a unique problem to myself, looks like I may be scouring plumbing sections for an alternative,
