Hi guys, just a quick one, what trigger wheels are you guys using? and where do you get them from?
i know i need 36-1 trigger wheel, but the only ones i can find are from "trigger wheels" and these need to mounted in the correct location, drilled and fixed.
is there one availble where i just replace the orignal pulley?
Thanks Colin
Trigger Wheel
superman
, Jan 15 2012 08:02 PM
4 replies to this topic
Posted 15 January 2012 - 08:02 PM
Posted 15 January 2012 - 08:27 PM
I bought the trigger wheels A-series one with the corresponding VR sensor bracket
Just Use the longer bolt they supply and insert it into the original 1275 crank pulley, no drilling etc. needed
MED do a toothed crank pulley i believe, but is a considerable amount more
Posted 15 January 2012 - 08:59 PM
thank you, just a couple of points
does this tigger wheel not move, or is it that using the longer bolt clamp both together?
Posted 17 January 2012 - 06:44 PM
Once you've torqued up the longer crank pulley bolt you'd have to be hercules to turn the trigger wheel in relation to the pulley
