Gear Selection Problems
12 replies to this topic
#1 MattEvans
MattEvans
  • 74 posts
Posted 16 January 2012 - 01:27 PM
Hi all,
The Car:
1982 HL with mid 80's standard metro 1275 engine (rod change)
The problem:
the last few months the car has been hard to change down from 3rd to 2nd. sometimes its worst than others and sometimes it feels fine, but more often than not it has taken a fair amount of force to push the gear lever from right to left. Also, i no longer had to lift the gear lever to find reverse, pulling it to the far right it would just slightly click, then i could pull it back towards myself to find reverse gear.
i just took the gear lever out and it looked a little dry so chucked a load of grease around it and put it back in. now i can no longer select 3rd or 4th or reverse! pulling the gear lever to the right just twists the whole assembly, but the lever doesnt actually move in relation to it.
Any ideas will be much appreciated!
Cheers,
Matt
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 16 January 2012 - 04:46 PM
remove the gear lever again and check there is a nylon ball attached to the bottom of it.
#3 MattEvans
MattEvans
  • 74 posts
Posted 16 January 2012 - 06:19 PM
Thanks for the reply.
I'll check tomorrow, but there's definitely a ball at the bottom of the lever (http://imageshack.us.../gearlever.gif/ see highlighted bit in pic) - i assume this is what you mean?
#4 lowrider
lowrider
  • 21 posts
  • Local Club: bmc
Posted 16 January 2012 - 09:43 PM
Check that the bolt on your remote stabilizer bar isnt loose as ive had that before
#5 Spitz
Spitz
  • 1,716 posts
Posted 16 January 2012 - 09:59 PM
That would be a rod shift...not remote.
Couple things to check before thinking of the worst case.
The shifter is supported by a rod that reaches forward to the dif housing, and two rubber "bobbins" just below your shift lever.
Get it up in the air and check that these rubber bobbins havn;t deteriorated away. Also check at the diff end to see that the bolt is in place.
#6 Dans
Dans
  • 69 posts
Posted 17 January 2012 - 01:09 PM
Hi, my mate has this exact problem, i spoke to him last night and he said that he was gonna try and get to the bottom of it today, will let you know how he gets on. However, he is a bit retarded so dont get your hopes up.
Dan
#7 lowrider
lowrider
  • 21 posts
  • Local Club: bmc
Posted 17 January 2012 - 01:36 PM
Hi sorry rod shift not remote ( had a blonde moment )
#8 lowrider
lowrider
  • 21 posts
  • Local Club: bmc
Posted 17 January 2012 - 01:52 PM
Hi sorry rod shift not remote ( had a blonde moment ) :whistling:
I know what i meant lol :gimme:
#9 MattEvans
MattEvans
  • 74 posts
Posted 17 January 2012 - 02:45 PM
hi all, thanks for all your replies (apart from dan, as i am his 'retarded friend' with the problem ¬_¬)
i've checked all that was suggested and it all seems fine. the two rubber 'bobbins' that holds the the shifter to the floor are fine, as are all the bolts holding them in place. the bolt is also tight on the dif end of the stabalizing arm, though there is a fair bit of side to side movement, but i assume that is normal?
any further suggestions?
cheers.
#10 Spitz
Spitz
  • 1,716 posts
Posted 17 January 2012 - 03:40 PM
Not really "normal" I don't think.
There is a bushing in there and also a rubber....perhaps this bushing is missing, allowing some movement. One wouldn't think this would cause your selection problem though.
http://www.somerford...age=page&id=152
(#33)
Edited by Spitz, 17 January 2012 - 03:41 PM.
#11 cliche
cliche
  • 896 posts
Posted 17 January 2012 - 03:44 PM
Hi Guessworks - I have the downshift problem from 3rd to 2nd gear on my A+ 1994 Spi. Is mine a different problem , i.e. a typical A+ 'box problem?
#12 Wright&Wright
Wright&Wright
  • 309 posts
  • Local Club: Central Mini Owners Club
Posted 17 January 2012 - 04:23 PM
Dan
I think I just wet myself reading that.
#13 MattEvans
MattEvans
  • 74 posts
Posted 18 January 2012 - 09:58 AM
(#33)
The part is there - however i think the outer part of it (rubber and all) has worn/perished away, just leaving the inner 'pipe' to which the 'u' shaped fixing on the end if the stabilizer bar slides over left/right
http://www.minispare...id=34986&title=
i removed the roll pins from the coupler yesterday, the gear lever then moved freely, so i guess it has to be something on the gearbox end of things. i have a spare engine in the garage so i'm going to feel the clockwise/counter clockwise movement on the rod while its in neutral and compare it with the one in the car. i guess if it moves freely on the garage engine, but not on the engine in my car then it must be a problem with the gearbox? in which case, i think my summer engine swap is going to get moved up the calendar! :/
Matt
Edited by MattEvans, 18 January 2012 - 10:06 AM.
