Thread Repair Kit For Head Studs.... Two Question's
14 replies to this topic
#1 me madjoe 90
me madjoe 90
  • 1,238 posts
  • Local Club: Fylde Mini Club
Posted 16 January 2012 - 09:08 PM
http://www.ebay.co.u...=item45ffe02757
Will this be the correct thread for repairing head stud threads in the block ....
Also has any one succesfuly used this type of kit with out any problems.
#2 Cooperman
  • 23,368 posts
Posted 16 January 2012 - 09:11 PM
Absolutely ideal for the job.
You need a pillar drill to drill the holes for tapping as it's vital the drill goes in vertically or the stud will end up at an angle.
#3 me madjoe 90
me madjoe 90
  • 1,238 posts
Posted 16 January 2012 - 09:14 PM
So you dont think it would be posible to do it on the car? as I dont realy want to be removing the block.
#4 Cooperman
  • 23,368 posts
Posted 16 January 2012 - 09:22 PM
I must confess to having done it with the engine in and using a hand-held electric drill. Not good practice really, but if only one or two are stripped it's worth a go.
Plug all the oil, water and push rod holes so that you can't get swarf down them. Then get someone to help and confirm when the drill is vertical. I used two pieces of aluminium extruded angle against the drill to try to keep it square and it did work as the stud was more-or-less vertical - still a bit of a bodge-job though.
Good luck with it.
#5 me madjoe 90
me madjoe 90
  • 1,238 posts
Posted 16 January 2012 - 09:33 PM
Better than what it is now... I know what you mean in the perfect world id love to do it properly. But i need the car and cant aford messing around stripping it.
It is only one stud and it lasted when i tapped it a year ago when the stud pulled the thread from the block. last minute quick job evening before work in morning. I dident expect it to hold for as long as it has.
helicoil should last lonnger than a year if it lasted a year just tapped and ramed in then. Our drill has spirit levels on it so might help with square and levelness.
Thank you for your help 'uncle cooperman' sounds strange saying that haha.
Edited by me madjoe 90, 16 January 2012 - 09:34 PM.
#6 sledgehammer
sledgehammer
  • 3,109 posts
Posted 16 January 2012 - 09:35 PM
It may be worth considering using a Magdrill with a normal chuck (not the rotabroach)- http://magdrill.com -
any hire shop will be able to rent you one cheap or something similar - even a bolt on drill base would work
the magnet is very strong on steel - so I can't see why it wouldn't work on a block
make sure you get the right voltage if you do rent one
ps a Mag drill with a rotabroach on steelwork is awesome - will even drill upside down without support (but with safety chain)
Edited by sledgehammer, 16 January 2012 - 09:39 PM.
#7 Blatherskite
Blatherskite
  • 501 posts
  • Local Club: Norsk Mini Cooper Club
Posted 16 January 2012 - 09:42 PM
Mind if you use a drill with spirit levels that the engine is also perfectly level, or you might drill a vertical hole into a tilted engine...
#8 Cooperman
  • 23,368 posts
Posted 16 January 2012 - 09:44 PM
Heli-coiling of stud and bolt holes on engine blocks is established good practice. In fact, on aluminium aero-engines all threaded holes have to be fitted with Heli-coils from new to avoid thread failure due to having steel bolts moving directly against aluminium threads at each strip down and re-build.
#9 me madjoe 90
me madjoe 90
  • 1,238 posts
Posted 16 January 2012 - 09:50 PM
verry good point ill go down the other route maby using a big engineers square or something symiler.
#10 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 16 January 2012 - 09:52 PM
With skill on the end of a battery drill, it won't be too hard to get it acceptably straight.
#11 me madjoe 90
me madjoe 90
  • 1,238 posts
Posted 16 January 2012 - 09:55 PM
looks good thanks for the idea may come in handy for future jobs at work. Although I think ill just drill it with a normal drill I have faith that it will be straight enougth... as i say dont want to become to much of an involved task. and its not muchof a high performance engine just an old fairly tired 998. =]
#12 mini13
mini13
  • 3,811 posts
Posted 16 January 2012 - 10:02 PM
Ive seen it done with a pillar drill bolted to the top of the block.
#13 me madjoe 90
me madjoe 90
  • 1,238 posts
Posted 16 January 2012 - 10:10 PM
You mean like a bench top one I may have one of these some where...
#14 tiger99
tiger99
  • 8,584 posts
Posted 17 January 2012 - 09:43 PM
Yes, a Black & Decker or other brand of drill stand is ok for what you are going to do. Lower the drill through the central hole in the base, drill a very short distance, say 1/4 inch, into the block, stop the drill, and with the end of the drill still engaged in the block, clamp the base of the stand down firmly (try bits of wood or metal, suitably drilled, between pairs of studs to clamp it down). You can then proceed to drill all the way.
Leave the stand clamped, put the tap in the chuck, and rotate BY HAND till the tap is started properly. (Assuming the tap is capable of being mounted properly in a drill chuck). Then you can take the drill away and use a tap wrench to complete the job.
#15 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 17 January 2012 - 10:10 PM
The Mag Drill is a good suggestion as it will be perpendicular to the top of the block when installed. However, before engaging the magnet place in the drill chuck the largest drill bit that will fit the stripped hole in the block. With the drill's quill extended so that drill bit goes into the stripped hole (drill motor not running of course) engage the magnet. That will center the chuck over the stripped hole. Now fit the HeliCoil tap drill to the chuck and continue as normal.
If a Mag Drill is not an option, AND you have a friend with a pillar drill, have him/her make a drill guide for you. Give them the HeliCoil drill bit and ask them to drill a hole through a flat block of aluminum at least an inch thick. Press that aluminum block on top of the engine block when you drill for the HeliCoil. The aluminum block will last long enough for you to drill a handful of holes and it will keep the drill bit perpendicular to the top of the engine block. That is much easier than trying to rig up a perpendicular fixture using angle iron or wood.
