Strong Exhaust Smell In Car
7 replies to this topic
#1 daenesh
daenesh
  • 423 posts
  • Local Club: Classic Car Owners Group
Posted 17 January 2012 - 05:24 AM
guys im daenesh from malaysia and i drive a 1978 mini clubman and normally when i drive with the windows open or closed there is a strong exhaust smell coming in the car.. and it gets stronger if i rev harder.. do any of you guys have any idea on my problem?
#2 jbs.998
jbs.998
    Previously known as Rockabillypsychosis
  • 928 posts
Posted 17 January 2012 - 06:04 AM
I would check all of the exhaust joints, mainly where the downpipe joins with the manifold.
Check with your hand for any exhaust leaks.
#3 daenesh
daenesh
  • 423 posts
Posted 17 January 2012 - 07:18 AM
thank you will check and let you know.. could there be any other reason besides that?
#4 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 17 January 2012 - 07:25 AM
is the exhaust blowing ?
#5 daenesh
daenesh
  • 423 posts
Posted 17 January 2012 - 07:52 AM
when its idling not much air is coming out from the exhaust..
#6 daenesh
daenesh
  • 423 posts
Posted 17 January 2012 - 08:00 AM
wad do you mean by exhaust blowing...
#7 charliedurrant
charliedurrant
  • 519 posts
  • Local Club: There isn't one down my way
Posted 17 January 2012 - 08:54 AM
What bungle means is that if you block the pipe at the back the engine should start to stall. If there are considerable leaks the gasses can't escape, the revs will drop and the engine eventually stop.
If there are leaks the above won't happen. If you are smelling fumes it is most likely at the exhaust manifold or the downpipe join as gases will leak into the engine bag, through the air vents and dash and into the cockpit.
You'll find the leak pretty quickly - note some times cracks can appear on the underside of the manifold so can't be seen by visual inspection.
Charlie
#8 daenesh
daenesh
  • 423 posts
Posted 18 January 2012 - 06:50 AM
ah ic ic... ill give it a try... thanks mate
