Cone Compression Tool
Posted 19 January 2012 - 02:03 PM
have seen a thread on here but the compression tool looks different to my compression tool ....please help!!!!
Posted 19 January 2012 - 02:23 PM
Obviously im answering blind here as i havent seen the one you have or the type you have seen. Im just going on the one ive used in the past.
Posted 19 January 2012 - 02:48 PM
Help!!
Posted 19 January 2012 - 02:49 PM
1. Take the tower bolt out
2. Place the sleeved tube over the long threaded bar (make sure the locknut is tight 1st!)
3. Insert into tower bolt hole and screw in about 6 or 7 turns
4. Now tighten the top handle on the threaded bar about 5 turns to strat with
5. Check to see if this is enough to allow top arm pin to come out freely, if not turn another full turn and repeat
Dont over compress the donuts, as they will likely destroy the threads and go BANG!!
Posted 19 January 2012 - 03:05 PM
Is there a video anywhere showing this procedure.....would be easier to follow probably.....?
Posted 19 January 2012 - 03:06 PM
The one i used had a ratchet handle built into it but was missing the spacer shaft so i had to make something up for it.
R1minimagic's post is spot on.
Posted 19 January 2012 - 03:18 PM
Compressor assembled, remove large turret bolt.
Then the threaded section shown on left of picture drops into turret hole and screws into a thread in the center of the suspension donut.
Then screw 2nd nut from right down so that it starts to pull the donut upwards (squeezing it), yours looks to only have one larger nut but still screw it down
Edited by lrostoke, 19 January 2012 - 03:20 PM.
Posted 19 January 2012 - 03:27 PM
Will have a bash later....I have a feeling i'm gonna break something lol....watch thhis ;space
Thanks again
Posted 19 January 2012 - 03:33 PM
Posted 19 January 2012 - 03:39 PM
A quick warning. While doing this job don't put you hands anywhere where they can be trapped if the tool or the tread in the spring fails. If this happenes there is a LOT of stored energy just waiting to remove fingers.
This is what happened to me on the fronts, didn't end up putting hi lows on the front because the tools just kept snapping back and it all came smashing togethor making a puff of dusty stuff, gosh it makes a bang!
Posted 19 January 2012 - 04:05 PM
Posted 19 January 2012 - 04:20 PM
Your not really selling this job to me guys........
BANG!
Posted 19 January 2012 - 04:21 PM
It's not difficult or particularly dangerous as long as you do it with a little care.
Posted 19 January 2012 - 04:26 PM
Posted 19 January 2012 - 05:06 PM
I make a good cup o tea
Well theres only one way to learn..................
