Basically what i'm doing is i'm telling you guys before i advertise it when its done so you can have a chance to call dibs
The work its had done so far-
Bodywork:
Complete new floor panels
new A panels on both sides
A posts repaired
Door post on passenger side
rear subframe front mounting panel
rear valace
rear valace strengtheners
front valace welded
scuttle panel passenger side
under scuttle passenger side
drivers side panel under rear window
new headlamp bowls (non metal)
Everything else:
New Starmag 13x7 wheels
Nankang tyres fitted (new)
Sportpack arches
Painted Tahiti blue
Cobra door cards
Black headlining
Black carpet
Thick soundproofing/ underlining
Parcel shelf in black
chrome opening window latches
Tex mirrors
engine bay in black
engine in black block/ red head
chrome engine styling- chrome rocker
Twin cooper 1 1/4 HS2 Carbs with chrome heatshield (rebuilt)
all rubber mountings (steadys, engine mounts, subframe mounts) replaced
front subframe repainted
rear subframe repainted
Gmax 25% uprated shocks fitted
serviced brakes
new discs fitted to the front
polished brake and clutch pots (metal kind not plastic- not servo assisted its too early for that)
front and rear original MK2 seats in black vinyl
engine partially rebuilt (new gaskets in most areas needed)
new alloy radiator fitted (uprated to normal one- rally standard)
twin boxster tipped stainless exhaust system (single box)
cooper 3 branch manifold
new air scoops (in engine bay)
dash in original condition
2 clock speedo unit
arches trimmed to accommodate 13x7's
floor mats fitted
new rubber pedal covers
underside completly covered in thick coating of Waxoyl hammerite undercoating (black)
poly mountings in several places (subframe tower mounts, rear subframe mounts)
2 rally chrome wipac spot lights on front with new 'made for clubman' mountings
2 rally chrome wipac fog lights on front with new 'made for clubman' mountings
chrome bumper
new rear chrome bumper fitted
over riders on front fitted
all new window seals fitted
all new door seals fitted
chrome wipers
6x9 fli's fitted in black speaker board under rear seats
under dash stereo fitted
engine weathershield
Stainless braided fuel hose in engine bay
clutch slave cylinder replaced
clubman badge fitted to back
probably other bits but cant think of them all lol
selling it for £5000 when its done in the following month or two
will be fully MOT'd and taxed
No offers please
Will swap for a BMW 3 series (2 door) in good nic of any age or a Ford Escort mk1/2 two door.
if i missed anything then kindly point it out and no jokers or time wasters thanks ive had quite enough of them
Note: car is not done yet- this is in advance
