Turbo 1275 A+ Questions
Posted 23 January 2012 - 12:10 AM
New to the idea of turbocharging, but the concept has been at the back of my mind for a while
Car will be used on a regular basis (Most days in summer hopefully, weather and reliability permitting!)
I have a 1275 A+ engine, would it be suitable as standard if it turns out to be in good condition, or would I require a turbo crank, cast dished pistons and stronger con-rods?
I presume the gearbox would be ok? The idea of a straight cut 5 speed seems too noisy and expensive.
So Far thinking:
HIF 44 Carb?
GT1752 Turbo
Mirage manifold (Although apparently they do not manufacture a downpipe for the GT17)
Turbo Minis Fast Road Head (don't know how they are in terms of quality and value for money?)
Bleed valve (Would I be correct in thinking this allows changing of the boost psi at the twist of a knob or am i being an idiot?)
Then beyond that I don't know, any thoughts, opinions or ideas would be much appreciated.
Posted 23 January 2012 - 12:12 AM
http://www.ebay.co.u...=item3362abf4d3
Posted 23 January 2012 - 12:22 AM
Posted 23 January 2012 - 12:27 AM
Posted 23 January 2012 - 11:24 AM
Posted 23 January 2012 - 01:04 PM
headwork £80-150 (depending on condition) / new head £300-£400
mirage £350
carb and plenuim £100+ (then consider a rebuild)
turbo £100-£200 (i know you can pick them up for £289 on ebay new i think)
downpipe fab £100-£200
mpi/spi tank £50-£70
turbo dizzy £???/ Megajolt £300
s/c drop gears £240?
boost gauge £50
fuel regualtor £40-£50
then you got fuel lines, addtional wiring, assuming you have a decent engine that requires no work and you can get compression low enough to get the boost you want.
obvioulsy i dont know prices but just something that may help you. as a lot of people say your better off aiming for a bhp figure and then seeing if your budget and engine can take it. if not then you need to compromise somewhere.
also really does depend on your starting point too. but there are always extra costs and i promise you there always are :)
Edited by t@z, 23 January 2012 - 01:07 PM.
Posted 23 January 2012 - 01:27 PM
Out of interest, whats the safe rev limit on a standard 1275 A+ engine, around 6000rpm to avoid excessive wear i'd guess?
Fraser.
Posted 23 January 2012 - 01:33 PM
but if you want it to last 4k is a safe bet :) (just kidding ofc)
Posted 23 January 2012 - 03:40 PM
Posted 23 January 2012 - 04:18 PM
so it would be safe to assume that the limit would be set when you get it rr'd. but there are a lot of factors to consider in my mind.
i've fixed mine to like 6k on my MJ at the moment until i get it rr'd, but mines a road fun car so i will be setting mine to safe limits too....whatever they will be.
if your really worried about wear etc and things breaking i'd just use your money and build a nice 1293, with a torquey cam and MJ on an SU or save for the SC single throttle body injection thing.
Not saying that turbos are high maint as its all about where you started from (engine) and how you drive but if you are worried.
Posted 23 January 2012 - 08:32 PM
Posted 23 January 2012 - 09:05 PM
Would SC drop gears make the car hard to drive, like a crash gearbox? I presume not as i would still have the synchro on all the gears? Or am I wrong here? My understanding is perhaps not as good as it should be haha
no it wouldnt change what the car is like to drive. there stronger and allot lot louder
Posted 23 January 2012 - 11:00 PM
just as an alternative im saying. my 1293 pre turbo and torquey cam was a blast and reliable. just think that if you want a turbo you need to be warey that things may go wrong at the the start where as NA they prob wont.
Edited by t@z, 23 January 2012 - 11:05 PM.
Posted 23 January 2012 - 11:08 PM
Posted 24 January 2012 - 09:32 AM
