I did not pay attention to the speedo and it is too late now to that since I already drained the engine oil. When I took the left pot joint out, the left differential output shaft flopped every which way and moves in and out about a half inch. There was a lot of swarf on the drain plug magnet and a significant amount came out with the oil.
The wheels did not counter rotate while on jackstands and in gear. I did not notice any difference in sound when I ran the engine and tried to drive in gear. However, there was an interesting detail. When lowering the car from the flat bed truck the operator and I noticed that the car was not rolling smoothly down the ramp. It seemed to be in gear. Sure enough, he missed finding neutral. I put in neutral and it was smooth after that.
Since I need to pull the engine, I am going to get an engine crane. I wanted to get one for other purposes anyway. My back is not as it used to be. Any suggestions on what do I need to buy or build to attach to the engine to do the lift? I do not want to use straps, even though I have some.
Any and all inputs are appreciated,
Ivan
PS
Something that might be of use for future reference. When I bought the car 2 years ago it was making a squeaking sound under acceleration only. I thought it was a crack on the floor which I never found. Then it misteriously dissapeared. Then, about six months later, once in a while I would feel a clunk when shifting and then this happened. The steady bushes had been previously replaced. So I wonder if the squeaking was the first symptom of the differential going.
Edited by xrocketengineer, 27 January 2012 - 04:44 PM.
