Which Welder
14 replies to this topic
#1 Msmith3327
Msmith3327
  • 220 posts
  • Local Club: Torbay Mini Club
Posted 25 January 2012 - 10:21 PM
If i were to buy a welder to use on the Mini, which of the following if any would be suitable? and I know this is gonna be a bloomin silly question but I am going to ask it anyway, they do just plug into a standard house plug socket dont they :withstupid:
http://www.ebay.co.u...=item2ebae6a352
http://www.ebay.co.u...=item460061dfee
http://www.ebay.co.u...=item2a18c2c854
http://www.ebay.co.u...=item46005715f9
#2 miniyellowmini
miniyellowmini
  • 595 posts
Posted 25 January 2012 - 10:28 PM
Can't really advise on a welder as like you I'm looking for one too. Don't think you need anything too special for basic bodywork repairs. Some will just plug in some wont. Most will work but I think I'm right in saying single/three phase wont.
Edited by miniyellowmini, 25 January 2012 - 10:30 PM.
#3 Frisco
Frisco
  • 417 posts
Posted 25 January 2012 - 10:49 PM
First one is a complete unknown most likely from China. Id stay well clear
Second is a Sip which are fairly ok for small diy type stuff. No mention of what size it is either.
Third one is a decent bit of kit. If its in good nick its what you want.
Forth is too small to handle thicker metal but clarke have a good name in the diy circles.
The oxford on is on a different level to the rest though. You do need to look over it properly though, they can go wrong and it's old
#4 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,146 posts
  • Name: Sean
Posted 25 January 2012 - 10:53 PM
None of the ones you've linked to!!
#5 tiger99
tiger99
  • 8,584 posts
Posted 25 January 2012 - 11:13 PM
The best place to ask is http://www.mig-weldi...forum/index.php
#6 tiger99
tiger99
  • 8,584 posts
Posted 25 January 2012 - 11:18 PM
Oh, amd I should add, forget about gasless or CO2 for welding thin metal, and the economics of disposable argon bottles are bad. It is worth getting a propeer cylinder of Argoshield Light, or equivalent from other suppliers, as it will give far better results, and is easier to use.
#7 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,076 posts
  • Name: Neil
Posted 26 January 2012 - 08:46 PM
This question has been asked numerous times however if you have got £250 or so available then the Clarke 135TE Turbo will meet all of your needs.
2nd hand welders can be hit and miss but if thats all you can afford then go for it. Small SIP welders have a very poor duty cycle (i killed mine quite quick many years ago)
Go gas and not gasless, there are other gas suppliers out there, do use a Argon CO2 mix but you can use CO2 if you have no other choice, have a search on here. .6mm wire is enough for what you want to do on a mini and buy a 5kg spool and not the 1kg reels. .8mm will do the job as well.
#8 Msmith3327
Msmith3327
  • 220 posts
Posted 01 February 2012 - 07:02 PM
Still not sure, would this one be ok ?
http://www.ebay.co.u...=item1c2355c3d1
#9 1275GTS
1275GTS
  • 668 posts
  • Local Club: bmc
Posted 01 February 2012 - 07:34 PM
i've got a clarke 135TE gas mig welder. i've had it for 7 years and had no problems. My next door neighbour has a sip and has nothing but trouble. Prior to the 135te i had a 120e for 15 years and had no problems with that either. The clarke welders in my opinion are good pieces of kit.
#10 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,035 posts
Posted 01 February 2012 - 07:44 PM
I would also go with the clarke welders, We have just bought a clarke 135te and have found it very good.
www.ebay.co.ukCLARKE-MIG-WELDER-135TE
#11 Msmith3327
Msmith3327
  • 220 posts
Posted 01 February 2012 - 07:55 PM
Unfortunatly I cant afford that much :shy:
#12 ibrooks
ibrooks
  • 1,017 posts
Posted 01 February 2012 - 08:24 PM
I doubt it. It's a big lump so although it says single phase it probably wants a 16Amp supply (a normal household plug is 13Amp max).
You also need to be careful of the minimum current. Screwfix have been selling cheapy ones recently but their minimum current is way too high for bodywork thickness metal.
I have a Clarke 150 that's brill. SIP have a very bad reputation in recent years and my little migmate 90 that I had before was terrible. The difference when I changed to the 150 was amazing. Strictly speaking the 150 should be on a bigger power socket than a 13Amp domestic one but at the lower settings it's never blown a fuze or breaker. I have had it pop a fuze when I was welding some hefty stuff and had it turned right up.
Iain
#13 Shifty
Shifty
  • 13,146 posts
  • Name: Sean
Posted 01 February 2012 - 08:31 PM
Thats a common mistake.
An inexperienced welder who buys the cheapest one he can lay his hands on, he uses the welder and discovers that his welds are crap. Its not him though its the welder at fault. He then gives up and/or makes a mess of it.
Cheap crap welders are awful things to use, I hate them.
Look at the amount of money you'll save by doing it yourself, the welder is an investment, especially if you plan on being a long term mini owner.
A decent clarke with a mask will be under £300, even if you only use it once it will fetch £150-£200 on ebay. You'll get a welder thats nice to use and won't be a liabillity.
#14 imvarma
imvarma
  • 153 posts
  • Local Club: Tatsu
Posted 01 February 2012 - 08:45 PM
I had the last one, was a good welder for all sorts of jobs, but I've just upgraded to the 135TE and as mentioned a quality weld can be obtained so much more easily I wish I'd just bought one of these in the first place...
#15 NuFab
NuFab
  • 88 posts
Posted 01 February 2012 - 09:09 PM
I've also got a Clarke welder, I think it's the 130 or 135, on gas. Gas supplies can be really expensive, but I found a guy in Worcester who does bottles at £25 deposit and £25 per refill, which is a bargain.
I'd agree with the sentiment about buying a good welder. I learnt to weld with mine, and it was hard enough using a brand new machine... It would have been a nightmare using one where I wasn't sure if it was working properly.
