Braided Fuel Hoses
Posted 28 January 2012 - 04:24 PM
I'm after fitting braided fuel hoses throughout my mini besides the main copper pipe. I've already done the rear of mini and am just querying the front really.
I have an electric fuel pump to the rear of mini and am just wondering which sizes hoses are required to the front and where now baring this in mind and also the fact I have an HIF44 carb fitted.
Any help much appreciated.
Chris
Posted 28 January 2012 - 04:28 PM
Regards Blue
Posted 28 January 2012 - 04:30 PM
Posted 02 February 2012 - 01:06 PM
Anyone else got anymore input? Maybe a pic or two?
Posted 02 February 2012 - 01:20 PM
Posted 02 February 2012 - 02:03 PM
I work it out (roughly) to be;
T-piece in boot to King filter in boot - 5" length
King Filter to Pump under Subframe - 12" length
Pump under Subframe to Main Feed - 7.5" length
Main Feed to Carb - 12" length
Is there any other lengths I need to account for? I get the feeling I'm missing one at least as theres to two pipe connectors on the carb?
Chris
Posted 02 February 2012 - 06:44 PM
was told this by people that do airoquip and braided lines etc at autosport, so i guess its true!
Edited by MiniclubmanGT, 02 February 2012 - 06:44 PM.
Posted 02 February 2012 - 06:51 PM
Posted 02 February 2012 - 08:27 PM
If it is one of these and you have an SU HIF44 then i would fit an adjustable fuel regulator just before the carb and set it at 2.5 / 3.0 psi as the SU does not need alot of pressure.
This may not be the case with your setup but i have done the above and it works very well,as for the fuel hose use the braided teflon and in one piece if your,e running it inside the car.
Posted 02 February 2012 - 08:43 PM
Thanks for the reply Ethel but I mean the lengths required.
Chris
Posted 02 February 2012 - 09:37 PM
Yeah, no worries, read that the other day, but I'm not running mine inside the mini althought it may be one to consider later down the line possibly.if you are running it inside the car make sure its the teflon type and not the rubber type, the smell of the petrol comes through the rubber type, it cannot cause fires and is no reason for concern, just smells a bit petrol-ey!
Yeah it is a Facet fuel pump (little square one), why put a fuel regulator on it? Won't cause pressure between the section of pipe? I'm not clued up on this so any advice would be much appreciated.If you have an electronic fuel pump is it a facet type(a little square one )or a cylindrical type (interuptor).
Chris
Posted 03 February 2012 - 07:45 PM
Thanks mingy, I'll get them ordered tomorrow then. Was a tad confused when looking at them trying to think back when it was all connected up haha.
was told this by people that do airoquip and braided lines etc at autosport, so i guess its true!Yeah it is a Facet fuel pump (little square one), why put a fuel regulator on it? Won't cause pressure between the section of pipe? I'm not clued up on this so any advice would be much appreciated.If you have an electronic fuel pump is it a facet type(a little square one )or a cylindrical type (interuptor).
Chris
