Su Hs6 On A 1275Cc ?
Posted 28 January 2012 - 10:00 PM
If I stuck one on my 1275, would it increase proformence or not?
Posted 28 January 2012 - 10:09 PM
Posted 28 January 2012 - 10:11 PM
Posted 28 January 2012 - 10:15 PM
Posted 28 January 2012 - 10:18 PM
Posted 28 January 2012 - 10:29 PM
Posted 28 January 2012 - 10:46 PM
Posted 28 January 2012 - 11:37 PM
Posted 28 January 2012 - 11:40 PM
The two carbs are the same diameter and will flow the same amount of air - especially if 'Vizardised' and any silly 'idle valve' removed from the butterfly . However the HIF does control the fuel level rather better than the HS carb - that's what the design is all about!
I have never like the bimetallic strip or the choke seals, ESP if you don't use the car all year.
Posted 29 January 2012 - 12:35 AM
Read page 75 Fig 7.1 2nd edition Vizard
hs6 flows 210 cfm
HIF6 flows 240 cfm
Posted 29 January 2012 - 04:42 PM
Posted 30 January 2012 - 01:29 AM
Posted 30 January 2012 - 10:49 AM
But if something produces more flow than another in a standard test then it must have less resistance, thus it will be less restrictive and will allow and engine to breath more easily.
untill it gets to the lower flowing head that negates that extra flow. Which goes back to what cooperman said
To some extent those figures are a bit acedemic. To achieve the max flow you need a head and cam combination which requires the carb to work a maximum capability. Not many engines actually have that and a road engine is most definately unlikely to. If the engine is only capable of receiving, say, 180 cfm, either an HS6 or an HIF44 will perform as well as each other.
Posted 30 January 2012 - 11:26 AM
